EXTENSION / REPLACEMENT CABLE for IEMs (Moondrop Starfield)
Hello,
So just got myself a pair of IEMs, Moondrop Starfield. They are sick, totally in love with them.
The problem is that in my dorm it’s hard to keep the audio jack close to me, so the stock cable is just too short. I’m looking for something to extend the stock cable and keep the quality, but I’m not too sure what kind of cable to look for. Need one extra meter. (1m)
It’s also ok to get a longer replacement/upgrade cable if it’s not going to break my bank. Got a budget of maximum 50 EUR. I’m in EU so something from EU or aliexpress is acceptable.
If anyone knows of any good stuff link it down here, I’d be thankful to take a look.
Thanks in advance!
This sounds like you just need a 3.5mm-terminated female > male extension?
I’d message XINHS they make awesome cables to what ever spec you require at a great price, the 4 core Graphene cables very nice and can be made to any length just ask them :+1:
https://xinhs.aliexpress.com/store/all-wholesale-products/910746107.html?spm=a2g0o.store_pc_home.pcShopHead_6000195636442.99
Yes, exactly. But not something that will look shit, or ruin the experience.
Bit late, but ended up ordering a cable from XINHS and using it for almost 2 years now, it’s perfect! Money well spent and totally recommended.
