Technically the earpads on the X2HR are replaceable, but is there anything out there that actually attaches to the headphones as the stock pads do?
What I’ve found so far appear only to fit over or work around the intended attachment system.
Anyone else have experience with the above or use 3rd party pads with these headphones? Which ones did you get and how have they worked out?
