Yet another problem with my btr5 : i was listening and the music was sped up and the voice became high pitched and it was skipping notes and the sound was scratchy , i unplugged it and plugged it yet another time and it came back to normal , do you think it’s again the btr5 fault ?
I want not to know if I can use my btr5 connected to a device using mini jack to a usb c adapter cable , is it possible ?
Hi there !
Its my first post here so I hope I wont make many mistakes !
For sure I guess my question has been debated before but the forum is so big… And as a noob I dont know much where to ask…
Im actually almost satisfied with my westone um20 pro / LG V30 tandem, but the phone is ending his life and I often have to manipulate my phone for my job or many reasons and get bored about cable.
Im a huge fan of heavy/extrême metal, HX hard/prog/stoner rock.
So Im asking myself : for 150e in France I can buy both this amp or a westone v2 Bluetooth “cable” .
As my music use is 100 % on this mobile setting and still as a nweebie, tell me if im right :
-the amp is perfect for good music no matter the Bt source (so I can buy even a crap but solid cheap phone for work), but another electronic stuff to load, carry etc
Or
-I keep buying an expensive good phone (v60 or the asus) and enjoy the simplicity of BT cable
Am I mostly right ?
when you set a eq in the app dose it get saved on the device so that you can also use the eq when using it in usb mode
and maybe a more important question is the btr5 still a good buy
I bought a second one when I lost the first one. Now that I have 2… 1 charges while I use the other one. I regret nothing.
Can’t connect my OnePlus7 Pro to USB-C BTR5, any ideas?
phone is not recognizing and not reacting to it
I have the same phone and it’s not a problem. If your cable quality is poor and sometimes you need to forget the Bluetooth pairing.
