Can someone please tell me if the equalizer function is available when used as a USB dac from a computer?
Thought this time they didnât f* it up. Even before the release I read on headfi that the EQ would work now with usbâŚ
supposed to be coming in a firmware update from what I heard.
hoping to have mine in a couple weeks but theyâll probably snail mail it.
They said the same about the btr5, never happened but hey, they delivered some kind of PEQ for the btr7 with an update so there is hope.
Thanks a lot for testing it! pitty it does not workâŚyetâŚthere is still hope as Fiio´s customer support ist definitely not the worst ![]()
I wonder how it is with K9 Pro, but probably same story
Yes, same story with K9. Fiio makes solid hardware but their software development needs improvement.
At least they are trying, lets hope for the best ![]()
I have an eye on K9 Pro, think i will just ask on headfi what the status is regarding this function, they seem to be pretty active in the forum
I thought they said something like âweâll look into itâ I donât remember an official confirmation on the 5
7 should unless they plan on partial refunding, getting a lawsuit or both
Does it allow you to apply a shelf filter?
Has anyone tried it with an Aeon 2 Noire? Can it power it?
So far only peak filter.
if bluetooth is the only improvement than my 5 is champ no need to upgrade
Darn. Okay, thanks for replying. Still progress though. Being able to place the number is better than with the btr5 2021 which is just a ball on a bar. which is impossible to get the right number with.
If anyone hasnât noticed the newest firmware update
The following changes and improvements have been made to the FW1.7.1:
Added PEQ function (go to the EQ menu on the latest FiiO Control app for settings);
Changed the setting of aptX Adaptive to off by default (can be enabled on the FiiO Control app);
Improved the logic of UI display;
Improved the abnormal issue of answering phone calls through the 4.4mm headphone output;
Miscellaneous performance improvements and bug fixes.
Noice - Looking forward to mine coming in.
I snaged a refurbished btr7 recently.
I dont really know why, but it didnât click with me. The thingâs really heavy for its size, and even though it doesnât really matter for my use case, I didnât really like it.
So long story short, I sent it back and have been refunded. I stay with my qudelix 5k for now.
Ifi go blu is same price i think. Has anyone compared the two?
Where could I find the refurb of Fiio? I am thinking about buying this BTR7 as an upgrade over Q5k as I hate 2.5mm socket, but also I am afraid of that being much less user friendly (q5k fits my case with Buds perfectly) ![]()
BRT7 heavy?
