I use my Beyerdynamics DT770 Pro (80 ohms) for general use and for gaming. I also use a pair of Hifiman HE-4xx when listening to music - from Tidal or from FLAC files.
I was thinking about upgrading the E10K on my desk to something better, say a Fiio K5 Pro or a ifi nano iDSD BL but I am not sure it will really make a difference.
Knowing my (basic) gear, do you think it’s worth it ? And which DAC would you consider buying ?
If you want more power, the k5 pro is great and will help out your 4xx as well. It has a built in dac that’s pretty good as well.
The nano isn’t as powerful as the k5 pro, but great for portable and desk use
I would consider saving up for a better pair of headphones though, unless you really don’t think you need an upgrade, but you will get more performance out of a higher end pair of headphones then a new dac/amp
Just a short feedback to tell you that I finally went for the FiiO Q5s.
It’s much more expesive but has all the bells and whistles in terms of connectivity. Now I can enjoy good sound, not only on my desk but in any place using my phone via LDAC. It beats my E10K on everything and by a significant margin, especially on precision, soundstage and imaging. I would also recommend using this DAC/AMP for online fps gaming because the very precise imaging really helps pinpointing your opponent’s footsteps.
I could’nt be more happy with that purchase as the DAC/AMP combo really make my HE-4xx shine.
