I just got my Q1 Mk II and been doing some tests.
I’m trying to make it work in DoP mode in the Fiio app (iPhone 6S) with DSD files and the only thing I hear is hiss and noise (no green light in the DAC). I´ve tried Audirvana on a Mac but I think that the decoding is made by the software itself (no green light in the DAC also).
I’m doing something wrong? Anyone have succeeded on making the DAC decode DSD natively?
So you have dop output selected when using the fiio app? Try unplugging the q1, making sure the fiio app is closed, plug in the q1 and turn it on, then open the fiio app and try again. Sometimes the fiio app will break and do what you mention
On mac it’s most likely doing d2p, but I am not familiar with Mac or Audirvana
I’ve found the solution and is this great app from the Japanese developer Cyberfort called “Kaiser Tone”.
There is a free version and a paid one, I could say it works perfectly and has lots of options and tweaks.
