So I decided to connect Fiio Q1 mk2 line out to Fiio A5 for a better drive HD600.
Does gain low or high option on Q1 have inpact on DAC’s line out? What is better option if it have?
Line out can be volume controlled so it is not fixed level.
You should keep your gain on low for the most part to reduce distortion, but I don’t know if it even effects the line out, since I haven’t tried it with my q1 ii
