Hi,
So I’m looking to purchase my first proper audio setup. I have just had IEMs up till now, a custom pair and a set of ER4XRs and I love them both, but I’m under the impression that IEMs cannot have the same sound quality, soundstage and imaging potential as a full size headphone so that’s what I’m looking into now
I’ve demoed quite a few, all of which were done on the Sennheiser HDV 820 amp
Focal clear
Arya
LCD 2 Classic
Sundara
HD800/ HD800s
I initially tried the Sundara because I was recommended to work my way up, but although it wasn’t a bad sound, I wasn’t ‘wowed’ at all, and I’m looking for something that’s above the quality of what I’ve already heard.
So I instantly put on the Arya after about 30mins of the Sundara to see the difference, and there was a big difference to the extent I started laughing and I thought this is what I needed, so I tried the HD800s just to compare (I’d heard it previously)
Now in comparison to the Arya, the HD800s sounded like it it was forcing me to focus on the details whereas the Arya was like playing in the background, like it was soft and while the detail was there, I sort of had to close my eyes and focus on it
I’ve never heard anyone say that before, so I’m assuming this is a situation where I had to up the gain setting or something, because I didn’t do that. The Arya was the only one of all these headphones were I felt like this. It sounded like the music was happening waayy too far away from me. I tested the LCD just because it was a planar and I wanted to know if that was what was going on, but the LCD didn’t sound far away at all.
I wanted to know if that was just my mistake or do they really sound like that? Because otherwise they were perfect, but this is a big deal breaker for me. I want the details in my face. I’m not looking for anything soft or something to listen to before bed, which is what the Aryas sounded like. Was I just supposed to change the gain switch? I had the HD800s on mid knob volume, and I put the Aryas a bit more to like 2o clock
Now onto the other headphones, I was really only interested in the comparison between HD800s and Arya regardless of how everything sounded because of what I had been described on the internet as their capabilities. They both sound like what I’m looking for as someone who primarily listens to orchestral music and I’m also a gamer, and judging by what I heard of the Sundara, this is the price range I should be looking at.
I listen to all kinds of music, the second most popular genre I listen to is pop, but the HD800s didn’t seem really all that bad when it came to it.
During this demo session, I also discovered that I preferred a bright sound signature based on I initially couldn’t really work out if I preferred the original HD800 or the HD800s, but I could tell what the difference was.
In terms of bass, I would like for the bass to be accurate, but I don’t really care for things like punch and slam. Really the only thing that is holding me back from the bass in terms of the HD800s is the fact that people are saying it is ‘distorted’ and I’m looking primarily for detail and accuracy.
I’d also like to ask if these two headphones are the only ones I should be looking at or not. Am I missing something before I purchase? I just want the most accurate, detailed and uncoloured sound. If any of you have any recommendations, I’d love to know.
Also, while I did end up deciding that the HD800s was the best out of all these options, I was sort of left feeling like while the imaging, staging and detail was much better than my Etys, everything else was kind of the same or worse. It made me think that really I should just stick to IEMs. What do you guys think about that? Are they really limited against these full sized cans?
