Looking for a tube amp for the hd6x0 line. I’m looking for a cheap and cheerful headphone amp for my second office (semi end of work from home) set up.
I’d like something that is smooth and musical. I’ll be pairing it with a nice DIY chip based r2r dac.
I’m open to DIY options, but the dollar/performance ratio is king. I’ll be replacing a thx 789. Budget would be $500 cad max or preferably less. I’m eyeing a used bottlehead crack or Eufonika amp right now. I wish the sw51+ amps were still available and cheap
Canada and less than $500 cad would be ideal. I understand that the TA-26 is kind of a dark voice clone. I was thinking a used crack might be a good step up.
BHC makes a lot of sense for you if you’re happy assembling.
I wouldn’t discount DarkVoice or xDuoo TA-26.
Those amps will come in under budget and give you a lot of wet “tubiness” for your money, with room to play with some tube rolling.
I would not be looking at hybrids in your situation where you’re seeking “tubiness”, variation from SS and synergy with 300Ω Senns. Go OTL.
No worries, I can solder fairly well. Used cracks seem to be pretty cheap too, but I’m worried I’d have to redo the bad solder job of the previous owner. Much less annoying to start from scratch.
