I have only tried supplied tips which were okay and bought the dekoni tips which are better but they still bother me after an hour or so.
What aspect of the tip bothers you? Is it the length? The material (foam or silicone)? The seal?
I have to put some effort in to make the dekoni tips get a good seal and after about an hour or so they start irritating my ear canal.
Do you have any issues with silicone irritating the canal?
There are hybrid tips like the Symbio W that are a silicon tip with foam that let you get a better seal if you don’t like the feeling of foam
https://symbioeartips.com/termek/symbio-w/
Silicone tips are comfortable but not a good seal. Those seam like a good solution. Thanks!
Another option might be ikko i planet foam tips as they don’t feel as rough as the dekoni tips imo, and shorter
Already ordered the symbio so I’ll see how those work.
