Yeah I donāt think itās fair to say itās dark. It would definitely sound warmer or darker than an HD800S into a THX amp though.
That, I think, is absolutely a fair thing to say. You are certainly right about that.
Thanks for your feedback.
The only reason I am considering the MG over the OG is the color. Iām a big fan of the new Chestnut MG color.
Given that the frequency response of the MG is darker than the OG, I would assume I could easily compensate that with EQ.
With regards to my current HD800S->THX887 setup, I have EQād it with Sonarworks, so it should be quite neutral. I donāt have any other experience with other headphones / amps / dacs
Thanks again
Iām biased but I have to say they really are some of the best looking headphones Iāve ever seen. I never get tired of looking at them.
Hello all,
I can buy them for around 1000ā¬/1100$ from a local retailer. What do you think people? Should I?
My most expensive headphone is Sundara right now. I also have Sennheiser 58x, Meze 99 Noir, X2HR, Beyerdynamic Custom One Pro and a few other. Iām relatively new to this hobby and enjoy most of my headphones for different genres of music.
Thanks in advance
Well, guess what: I swiped their Last pair for around 900$. Pretty ridiculous.
Man, am I excited. Canāt wait for them to arrive.
How do you like them?
I feel like I havenāt spent enough time with them nor have I burned them in. I also bought a pair of Klipsch HP-3s around the same time and spent most of my time with it. For now, I feel like they are pretty mid-forward instead of neutral. If I raise the volume to have a more engaging experience it becomes shouty I guess. So it kind of reminds me @WaveTheory 's review. Still take my comment with lots of salt. Iām new to this hobby.
Still I like them. I think they should be one of the best at what they do. Detail retrieval is like shooting laser beams.
My current / latest setup with the Clear Mg. Bifrost 2 ā Jot 2, with a Hart Audio Cable, headband pad (mostly to avoid getting any oils or anything directly onto the pad), and Iāve settled on the Dekoni Sheepskin Fenestrated pads for the best long-term comfort while listening but also fantastic sound signature.
There are a lot of upgrade paths Iād still like to listen to and discover but currently this setup just⦠Iāve just not heard anything better than this for my personal tastes.
Iām still debating wanting to try the Singxer SA-1 or Rebel Amp after @MrAyritās review but this is just a really nice listen currently.
Mmm, you may want to try a tube route. Iāve got some Utopias on hand right now, and through the Bottlehead Crack they are exceptional. Singxer feels a tad sterile in comparison.
You know itās weird, I have a DarkVoice with some upgraded tubes but the Clear Mgās sound⦠weird through it. I know theyāre relatively low impedance so I wonder if that has something to do with it. The 660s sound much better through them.
Iām curiousā¦how much different is the sound with the Dekoni pads? I really miss my Clear MG and had not considered a different pad. I couldnāt do the pads that came with them due to a skin allergy or irritation. The dyes on the Red pads were terrible.
Got the MGs a month ago now. Exactly what I wanted to compliment my neutral bright Aryaās and as an upgrade from Elegiaās.
Neutral warm but without losing the fine details, fantastic imaging, soundstage is perfect for mix/mastering purposes for me.
They are fantastic on the RNHP, great on the G111 for a tiny bit more width but it sounds like the lows are slightly boosted and the highs are slightly reduced. They are just a bit more neutral and refined on the RNHP.
Both G111 & RNHP are fed by a JNOG, the G111 / MGs would benefit from a Soekris or brighter DAC in general.
Highly recommend these if you like the Focal sound but without that slightly metallic sound some mention about the rest of the Focalās.
My number one priority is comfort. The stock pads are great but I wear them so much I started to feel them breaking in to the point that my left one was verrrrrry close if not almost touching the driver, which happened to me on the Celestee.
I tried several Dekoni Focal pads (left around from when I had the Celestee and Elegia). The Elite Velours are comfortable but got a little hot after a while and really muddied the sound to my ears. I wouldnāt recommend them.
The Elite Hybrids for sure elevate the bass and roll off the high end but are more comfortable and I liked their depth and firmness. A decent compromise but not perfect.
Won a little money playing poker so I went for the nearly $100 Fenestrated Sheepskin pads and it was like Goldilocksā Earpads. Firm, but comfortable for long listening sessions. There is still a small change in the sound, but the bass is pleasantly raised a little bit and I havenāt really A/B tested it that much but I do think the mids and highs are pretty true and sound as good to me. Iām not an analytical listener though so donāt take my word for it.
For what I was looking for, they fit the bill perfectly.
Oh I didnāt know about this. I recently got SMSL SP400 to do justice to my Clear MGs but always regreted not being able to get an SA-1. As some of you may know, SP400 also suffers from low gain issue. You can use all of your volume range but having a headroom gives an feeling of safety.
He lost me when he said these can be sibilant. Anything can be sibilant at this point I guess. Otherwise I agree with him. Also last week I asked @ResolveReviews during the stream what did he think on Chronoās take. If I remember correctly, he said mostly he agreed with Chrono but restated he prefers OG Clear.
Alrighty folks, interested in a little bit of advice here. What tube amp would you recommend for these guys? Iāve got a Bottlehead Crack with Speedballāit sounds good, but the low end is a little muddy. Anything out there that isnāt crazy price ($500-1000) that would clean it up a little down low, but keep the fun and liveliness of the Cracks mids and top end?
Iām curious about the Bottlehead Mainline.
Iād imagine the Mainline would be a better fit. Output impedance on Crack is pretty high for 55Ī©
Any other options I should look at?
