Found a Audio Optimized USB cable
USB works because it has tight specs hardware has to meet. When you want things to work, you stay within those spec.
USB 2.0 Spec
This is how SiliconLabs spcifies the circuit arround their EFM32 chip. The coils looking things with the line next to them is a ferrite core.
No
No, it is not.
Standard cable works and performs like it should.
Customized cable might work more weakly/poorly and not perform as good.
In technical sense.
Unless some like do add so called “Seasoning oil” to their daily dose of audio. :wink:
Oh yea, and this. Since USB is mentioned.
wow, ok. well i got this instead:
I mean, some wear different colored shoes or label them 1 & 2 so they don’t confuse left and right.
Anyways you can order pretty much any colored and standard spec qualified USB-cables in pretty much with any length.
how did you know i did that? are you psychic?
