Found a Audio Optimized USB cable for my SU8 DAC:
Company sells other usb audio cables Amazon.com: DJ TechTools
But how is it audio optimized
What’s supposed to make this snake oil “audio optimized”?
I don’t think it’s snake oil, but more just a light marketing tactic
Has a 56K Resistor in it to prevent your devices from overdrawing power
Dual slimline ferrites and braided shielding to prevent signal dropouts during live performances
USB audio is an error tolerant protocol, every packet has a checksum.
Either you get the bits or you don’t.
I see that’s what it says on the product page, but the resistor doesn’t affect the audio aspect and is mainly there just to prevent damage. Most usb cables with a resistor would do this just as well.
The shielding would be nice and all, but if you aren’t having issues with your current cable, I don’t really see the need to get a new one. It does seem like a nice cable but it might be an unnecessary purchase if the one you have works fine
The main thing I would want for audio would be a cable with built in isolator to prevent ground loops tbh
Yes there is value in that, especially with battery operated devices, or ungrounded devices in the loop.
the one that comes with the SU8 is ugly grey and short. Also i got a open USB C port on my comp not being used. this cable is longer, distinctive and will connect to USB-C.
I just dont like buying cables for my audio that are supposed to connect printers. it bugs me. i want something more for audio, and if its a good cheap price, i’ll buy it.
Yeah, than go for it, should get the job done ![]()
wait a minute, where can you buy cables with Isolaters?
Inline I don’t know, but I like these from iFi, they do the job very well
There is also the iSilencer if you have those issues
It’s not worth it unless you have ground issues.
Basically they use optical couplers to isolate the power from each device.
Neither side sees power form the other, so you don’t end up with ground issues.
The easiest way to avoid ground issues, assuming your house has decent power is just to use grounded devices and plug everything into the same outlet.
Just like any other digital protocol, USB either works or does not work.
Overspending on a cable because “it says audio” is like buying a chair because “it says gaming”: Pointless
but the resistor though
and its blue, i wont get it confused with other “computer” cables.
The Resistor puts it outside of USB spec.
And the dual slimline ferrites and braided shielding to prevent signal dropouts.
what do you mean? is that a good thing?
