Found a decent Bluetooth Cable for MMCX (Used with a Tin T2)
So I’ve been on the hunt for a good MMCX Bluetooth cable for working out and just got this one.
https://www.aliexpress.com/item/33031249596.html?spm=a2g0s.9042311.0.0.5d184c4d3EdHlh
Been using it with my Tin T2, so far its pretty decent.
Sound -Sounds pretty good, still have to listen to more songs but I’d say pretty great for Spotify listen as you work out. The mic sounds decent enough as well, made a few phone calls sound is pretty clear.
Battery - claims About 20 hours, have yet to fully test that out but I think its fairly accurate.
Construction and Fit - sits pretty snug on the neck. the only issue is that the middle section cable is rigid - which is good for staying around your neck (right now its a bit too snug but it will probably soften up in time) the issue is storing it though It might get better as the cable softens.
P.S i have another on the way to try out with my Blon-Bl03 will update that too
