Fps headphones recommendation
I will be playing apex,overwatch,six siege,tarkarov and battlefield . Which headphones purely for these games is the best? Is dt1990 a overkill for them? Or is dt880 600ohm or sennheiser hd58x will be a good choice.
An 880 600 ohm or 58x will be good enough for the most part the 1990 is bettter. But if you don’t have a ultra light mouse that fits your hand properly or a high refresh rate monitor yet I would prioritise spending more on those cause sound can only get you so far in fps games.
i have a good mouse and monitor so thats not an issue. How much better is 1990 than 880?is it worth 300 dollars more?
All up to your ears and ability to discern a difference and your own idea of value
