Yah, I made a 3D printed mod for the 6xx/600/650 whatever. It still needs the custom cans mod to make it work, but I’ll just copy/paste the instructions I posted on SBAF here.
I’m officially dubbing this the CQC 6XX mod. Why? Because you need the Custom Cans mod kit to do this for now, and it’s an homage to two of my favourite things. Mods, please change the title.
So… who is this mod NOT for?
- This makes the headphones less forgiving IMO. If you have compressed music you’re going to hear it. It might be better to stick to a stock HD6XX for that.
- If you like the upper mid range resonance on certain tracks, don’t use this mod.
- If you don’t like feeling bass on your ear don’t do this mod. I know there are some sensitive to this kind of thing, but I love it.
Who is this mod FOR?
- People who can’t stand the 4K resonance of the stock 6xx
- People who want extended and cleaner bass
- People who want extended treble
Measurements courtesy of JK47:
To be posted
Thing You’ll need
1x Custom Cans Mod Kit of which I am currently completely unaffiliated with. Tuning of this mod was done with the #3 foam. https://customcans.co.uk/shop/produ…l-plated-cnc-copper-mass-loading-mod-diy-kit/
1x Second Skin mod pack. Damplifier Pro: Custom Cut Small Project Sheets - Second Skin Audio
Tolerance is very tight on the print so use this product specifically. One sheet is good for two headphones with some room for error. The key thing is the product is only 1mm in height. This is the same stuff people were doing the KISS mod with so you might already have some on hand.
1x velcro straps from a Canadian Dollar store called Dollarama. They look like this and come in black or white:
I’m sure You can probably find these around the world under various brands. Here in the land of Maple Syrup they cost $1.25 CAD a pack and are good for one pair of headphones so buy more if you are going to mod more. Specifically we are going to use this to stop reflections on the inner diameter of the 3d print. I chose this product because it is cheap and easy to acquire with an already applied adhesive on one side. We are only going to use the soft felt side so you can throw away the hard abrasive side.
Access to a 3D printer that can print PLA or PETG. Even a very cheap printer can handle this print. See the STL file here:
https://www.thingiverse.com/thing:6612643 MAKE SURE YOU FOLLOW THE PRINT INSTRUCTIONS ON THINGVERSE!
Any Senn HD6X0 headphone. My understanding is that with the different custom foams with the mod kit the headphone can be tuned to sound like 600, 650 or 6xx anyways. Anecdotally the custom cans kit made my made in Ireland 6xx sound identical to my end of 2022 6xx. Previously the made in Ireland was slightly smoother in the upper mid range. The difference appeared to be the foam in the spider for the most part.
I won’t post my impressions here as I’d like to hear what other people think and I don’t want to influence them. For reference, my gear for tuning was a Pi2AES 2.0 with FLAC files running Volumio connected to a blue jeans coax cable to a Denafrips Ares 2 connected to a fully modded out crack running a Tung Sol 7236 power tube and RCA clear top input tube with some cheap monoprice RCA cables. Cable between the crack and the headphone was custom made using some Mogami 2534.
Instructions to follow in the next post.
