Fun IEMS for the Gym?
Been a while since I’ve been here, my current Rosefinch’s are slowly dying after being abused whenever I hit the gym or do yardwork. So I’m looking to explore for another fun pair to try out. Anyone know any recommendations?
I mainly listen to energetic and adrenaline boosting music. Stuff like Metalcore, Synthwave, Video Game soundtracks. Stuff $50 or less, similar price to the Rosefinch is better, since I’ll be using them mainly for the gym. Good fit and with a decent cable, if it has a mic, even better.
The 7hz Salnotes Zero:2 are amazing, and if you want more bass the Moondrop Chu II will do the job. Both are $25 and I think on Amazon I saw mic versions available. An Apple 3.5mm USB adapter for $9 will blow the doors off volume on them and most IEMs and sounds good too.
Thanks, I’ll check them out. Do they have a more harman neutral signature? I know quite a few of Moondrops IEMs have a harman signature. I’m looking for more of a V shaped sound.
Also not to flex, but my phone still has a headphone jack (Xperia).
I have been using the Roseselsa Star City 5 Pro.
I have been using Shure BT2 for Gym, flexibility to change the iem to any with mmcx port is really helpful
Try tanchjim one dsp. Excellent set. You will love it.
Although I don’t go to gym, I use Go Pods + Xelento 2nd gen for runs and walks.
For gym workouts and yardwork, I’d recommend going with a TWS option. The practicality is hard to beat. While they might not match the sound fidelity of wired alternatives, the convenience is unmatched. They don’t require an amp and even come with a basic mic.
I suggest trying the Moondrop Space Travel. It has great sound for its price and include nice, basic ANC. Plus, you can adjust them to a V-shaped sound profile using the Moondrop app. The app is not great but it works fine for basic adjustments like that.
If you’re looking for wired options, the 7Hz Salnotes Zero:2 and Chu II deliver significantly better fidelity compared to most V-shaped IEMs in this price range. You can also tweak them to a V-shaped sound with a simple EQ adjustment.
I’m listening to the Moondrop Chu 2 that just came back from Audiosciencereview that got measured for the review Amir did. You can see the chart there to see if it’s your kind of profile.
I’m listening to the Platinum Collection by Enigma and some of the tracks on these are just amazing, not even taking into consideration the price. Since it’s the pair he actually measured I’m keeping them since they’re so dialed in (and not selling them for $20 with a calibration profile, no way).
These are 18 ohm, I have a Moto G Power also with a 3.5mm jack. The problem to look out for is check the output impedence on the phone to make sure it’s low enough your IEM doesn’t have an ohm rating more than 8 times higher. I just use the Apple adapter to ensure the sound profile doesn’t change. It has less than 1 ohm output impedance, and many phones are a lot higher than that, so low ohm IEMs will sound horrible (and the jack doesn’t have enough power to drive higher ohm rated headphones). It’s the best $9 investment you can make.
Having them on now, I can really recommend the Moondrop Chu 2. Also they’re low profile and stealthy looking. Going to get a black multi kit cable for them on Aliexpress later, but the stock cable is actually pretty good (non tangle).
Agreed, they’re likely the best value. There’s a version with DSP, which I believe costs the same, and it includes a USB-C cable and a mic.
I was thinking of trying TWS, but I’m not completely sure what Wireless IEM adapters would be worth buying. And I absolutely despise TWS with touch controls.
Get Go Pods + any of your fav iems :slight_smile:
Any chance there’s a cheaper option lol. They look nice but $400 is just too much. I’d be willing to spend ~$100.
Fiio UTWS5
https://www.aliexpress.com/item/1005006811892478.html?spm=a2g0o.productlist.main.5.78b2aHbsaHbs4D&algo_pvid=28ba3f17-5abb-486e-b752-f6d119d1eb5e&algo_exp_id=28ba3f17-5abb-486e-b752-f6d119d1eb5e-2&pdp_npi=4%40dis!GBP!103.00!35.57!!!129.38!44.68!%40211b600517213591896957699e6114!12000038495603149!sea!UK!2181805173!&curPageLogUid=dqtR1OEQJ7IH&utparam-url=scene%3Asearch|query_from%3A
Got both the Chu 2 and Zero 2s, gotta say I’m quite impressed, especially with the Zero 2s. Fun and has great clarity. The Chu 2s are great as well, but I seem to grab the Zeros more.
which is why I rec using a tws adapter like the TRN BT20Pro
I see a lot of adapters from also KZ, are the TRNs just overall the better product?
I have not tried the ones from KZ and neither would I cuz of their scummy behavior.
The TRN BT20XS (Pro is the newest version) is one I own and love as it has a crazy battery life that lasts forever and no noise.
It is better than the Fiio UTWS3 which I also have but is now e-waste because it does not work anymore.
For me my gym set for a while was the ISN H20, great midrange with BASS. Now I’ve resorted to Airpod pros for the noise cancelation. The shitty morning exercise class music was killing me. I could do better i know but sometimes convivence wins all. Im also there to workout not listen, I just need backround music to keep me focused. The Kz castor Bass was another cheep fun set for the gym. I will not bring a set to the gym that’s over 100. Things can go so wrong so quick with that dang cable hanging off me.
