Galaxy Earbuds Pro 2 or FiiO FD3 Pro
Hi
I planning to buy new earbuds. The sound quality is important to me. Which earbud your recommend:
Galaxy Earbuds Pro 2 (wireless) or FiiO FD3 Pro (wired)
The difference between mention buds is few or more in sound quality?
Thanks
Neither one nor the other. Look here
Thanks for the rec man.
@drjackool but flatheads earbuds arent recommended if you need isolation. In which case my advice is, if you do not care about Active noise Cancellation or other features like that, I would recommend just getting the TRN BT20 Pro and pair it up with whatever wired iem you want, you get better sound (generally) than mainstream tws flagships while still being a tws.
