Just wanted to say hello, my first post.
Down to business.
I have been doing some research but I decided that sometimes its best just to ask the pros.
I am a PC gamer. Specially I play a lot of Hunt: Showdown.
Current setup is a Schitt Modi 2 and Magni 2 (schitt stack)
Philips Fidelo X2, I also have a AGK K553 Pros and Fostex Th-x00.
I have no issues with this setup for movies, music and single player gaming. The issue is with competitive gaming. The X2s have a great soundstage but lacks in imaging and sometimes I find its too wide and I have trouble pinpointing sounds. The AGKs are ok⦠I am not a fan of closed back. They were an impulse buy for work. The Fostexs are really great for music/movies but not much else.
I would prefer Semi-open or open-back cans.
Budget is around 300 but fine with spending more or less.
If you like the sound stage and imaging(accuracy of where sounds are coming from), of the AGKās, might I recommend trying an eq or two out before deciding that a closed back just canāt work. From my experience it can help a lot depending on how the drivers are tuned out of the box. Sorry I have no recommendations other than that, but hey this is one you can try for free. Hopefully someone else will be more helpful than me. Good luck!
Thanks for you post. I am not sure why you withdrew it but thatās ok. I still got to read it.
I have considered the dt880. I remember reading that the 600ohm version was preferred. Not sure if thatās if that is my memory failing me or not.
Donāt the special editions have different tonality then the normal versions? I.E black edition and chrome edition.
Hey so the reason i withdraw it is that iām slowly changing my mind and i didnāt want to give you bad advice. iām still new to this. and as it turns out i might be or turn into an audiophile lol. iāve been doing a lot of A/B-ing today. and the more i go back and forth, i realise that i mightāve read too many opinions on the internet.
everything i wrote applies in terms of their properties. but after i just had a longer session with the Tygr i realised, while the bass is nice and thumpy that it actually becomes fatiguing and distracting after a while. i didnāt consider it, because you read mostly about treble when looking up beyerdynamics. so thatās all i listened for. i might not be a v-shape guy after all.
the more i go through my library of music the more i fall in love with the DT880.
so bottom line: i canāt recommend one over the other right now. but for what you describe, competitive FPS with focus on footsteps, they are all really good. i can just tell you that the DT990 is intense and too intense for me. aside from that itās probably better to test them side by side for yourself, if you decide that you are interested.
yea, i read that too. but from what i remember, itās the ear pads only. and those are easy to change. i just loved the look of the black with the different headband and stuff. i might even try Tygr ear pads on these, if i end up with them and treble keeps haunting me. apparently they have more bass, which i donāt mind since normal DT880 are supposed to not have much. i donāt know. iām mostly confused now.
sorry for the long posts and hijacking your thread. i guess iām not done deciding lol.
PS.: i will edit the first post and remove the conclusion
The updated pads move the headphones a littler further away which has the effect of increasing the sound stage and giving more of a sense of space.
Another headphone I like for gaming is the Fostex T60RP of course you can also update the pads on those, I recommend the Lambskin Alpha Pads. It has more of a straightforward and detailed sound than the HD660s which is probably better suited to most games. Both are great though for different reasons!
I totally feel you on that! That is how I feel about lots of high end headphones and that is why I still love the HD600 series, (currently have the HD660s). They have a nice full and detailed sound without being fatiguing. I really like my Fostex T60RPās but sometimes that bass compels me to turn down the volume, even with the Alpha Pads. And the Fostex are not bass head headphones but can still be overbearing on some tracks because they are very accurate on the low end like many planar magnetics are.
I will try to keep this simple, I donāt feel like typing a wall but I definitely donāt agree with some opinions here lol.
If your looking for competitive gaming, I do want to clear something here⦠bass is -not- a pro⦠it is a con of which 990 has too much bass⦠The only shooter I have played with some amounts of bass was acceptable and more appreciated was rainbow six but only in small amounts, Hunt does have some of those similar sound frequencies so it can tolerate some bass as well.
I would recommend just trying out the beyers⦠if your at all treble intolerant, like whatsoever⦠skip the 990s immediately⦠try the 880s or try the tygr 300r. Tygr 300r is a redone up 990 in low ohms⦠it becomes boomy, uncontrolled, veiled, etc if you donāt power it correctly⦠forewarning there⦠just like the regular 990 can become hollow among other weird sound issues⦠they use old yet very picky drivers that need an amp they synergize with to sound right. Regular motherboards for example make the tygr bassier than it really is on a normal clean amp.
In your budget I would say either the beyers or if your okay with some slight imaging inaccuracies you could check AKGās k7 series such as k702, k712, drop k7xx⦠just depends on what signature your looking for in particular as I donāt seem to see what kinda sound you prefer.
I think I landed on the dt 880s. The trouble is which version.
My plan is to order a special edition and a standard edition and see if there is a difference sound-wise. Probably both 600ohm if available.
From my research there appears to be a difference in sound not just cosmetics, headband, etc. I know its a little lame to buy 2 with the intention of returning one. Unfortunately now days its tough to find a way to test multiple products any other way.
Is there a vendor who can modify the Dt880s with a removable cord? I could see that being an annoyance overtime.
special edition black 250 ohm had a different tuning that is widely considered, from what I have seen, quite bad⦠all others are just aesthetics. 600 ohm is the best sounding of the 880s provided of course⦠you have a powerful amp to drive them
I wouldnāt bother with pro versions⦠they have a coiled cable and more clamp⦠I would just say go with the edition or premium(same thing) and go with whichever you think looks better to youā¦
store wise? no, not to my knowledge but there are people who offer this as a service through like Etsy and some other placesā¦
they are passable and similar to the pc38x in performance. Not bad, not the best⦠better than 38x for music.
Thank you Felenkor.
I picked up the dt880 premium 600 edition. Standard grey. The only people who had it in stock was Sweetwater and newegg. I went with Sweetwater as I have ordered a couple things from them in the past with good results.
I think my setup has enough juice to for a 600ohm headset.
I will check on etsy about the modding. I am not comfortable doing it myself.
On a side note:
I had the pc38x and returned them.
My main issues were imaging, comfort, and the microphone. The biggest issue I had was volume. I couldnāt use them with my Schitt dac/amp because I would get feedback if I plugged in the mic. So using them on the motherboard alone they just were not loud enough. I thought about buying a Schitt Hel or equivalent but it just didnt make sense to me.
Should be fine, havenāt tried magni 2 but magni 3 can run them just fine.
yeah, I believe theres been a guy people use on here for that from etsy⦠he charges like⦠I think $70 for the service.
I honestly, despise⦠this headset. Itās good for a headset, but everything else is just meh. It got shilled hard in my opinion which aggravates me to no end because itās performance is just barely better than the other open back headsets on the line. Imaging is fine but it has issues at 9 and 11 oclock where it just falls apart, separation of sounds is horrible so heated gunfights or games of larger caliber it suffers due to around average soundstage. Mic is sub par as well⦠I only recommend it if someone absolutely needs a headset in particular⦠but for me the headset doesnāt fit my ears properly like most sennheisers and I prefer AKG or Beyerdynamic over them⦠I just wish there was other options for great sounding mids like sennheiser
if your going to upgrade man, I would say save up and swing for the asgard or if you want a more measurement based cleaner amp from schiit just go to magnius⦠but I would absolutely sooner just say asgard and Modius⦠You can get them off the used markets in very good condition for like $150 per unit so $300 for the setup⦠I wouldnāt say you really need more than that for a gamer
I have been trying to see if theres a chrome version or something for 600 ohms⦠I believe there is but hard to find lol. Theres a lot of aesthetic variants of the beyers⦠but the black version vs the grey they do have different pads but only slightly
Demevalos on etsy, but heās upped the price for single ended to $85 by the look of things. Heās the guy with the guide people usually follow for beyerdynamic mods.
Iād probably pay the extra money ($15) for balanced simply because it gives you more amp options if you decide to make any changes in the future.
you can use the modi if you want, but I would recommend an upgrade at some point or another⦠donāt really need the dac built in though as you can get a modius for the same price as the built in
Got my Dt880 600ohm today. I have to say they are pretty great. I noticed an improvement for sure when gaming. I actually think they are pretty nice music headphones to boot.
Thanks again for your recommendations. I will picking up a Asgard in the near future too.
