In SS mode it is flat neutral, to me. In tube mode it is just a little bit tubey. Tube+ gives you a bit more, but not Very coloured at all. I prefer it in tube mode vs SS all the time, but that could just be in my head.
I found the LP to be a little more coloured, depending on the tubes used, but closer to neutral than tubey.
Hello,
For tube amps I’ll throw in the Feliks Echo 2,Woo Audio wa6,and of course the Quicksilver.
All three do nothing wrong for the money.
Another option would be the Bottle Head crack but not really my cup of tea.
Wavetheory reviewed the Cayhin here in the forum.
Whether the Ify is really a hybrid amplifier is a bit doubtful.
I think it’s more of a technical innovation that they’ve tried.
Otherwise, the Woo Audio Firevlies is a hybrid amplifier that Z review’s recently reviewed, but it costs $1400.
Great suggestions, but all a little pricey for me.
I watched that new Zeos review. It looks awesome, but would be about $2K landed, in Canada. I see that the second gen. is a pretty good price though. I have never heard a Woo amp.
I don’t have the headphones for the Crack.
I find the iFi stone neutral. The only reasons that I bought it, and keep it, are three fold:
Hello,
yes didn’t mean to rage against Ify, it doesn’t have to be a bad thing.
On the contrary, I think it’s brave and if it’s good, it’s all good.
What is the approximate cost of $500 to import into Canada?
Just to get a feeling for it.
You would do the least wrong with the Woo and Quicksilver.
There is also the Little Dot Mk2-3-4-5 and maybe the mk 3 Se.
I would distance myself from the Dark voice Xudoo.
The Xudoo is supposed to be a copy of the Dark Voice, and the Dark Voice likes to have a humming sound and high prices for tube rolling.
An alternative would be 1101 Audio, which still has something and is based in Canada.
But he is supposed to be quite booked up.
On Ebay you can still find Eufonika.
This is a handmade Otl from Poland with good results and a very reasonable price.
I do love my iFi, for the reasons mentioned above.
I just sold a Little Dot MKIII a few weeks ago.
I have looked hard at the Crack, the Dark Voice, the Eufonica’s, etc. All of these companies recommend a minimum Ohm rating of 100 Ohms for the headphones used. I currently own ten sets of headphone and have two of them up for sale. And will likely move more.
Right now I am working with:
GH2’s = 32 Ohm @SPL of 99.8
Freq. range of 14Hz - 28Khz
Elex’s = 80 Ohm @ SPL of 104
Freq. range of 5Hz - 23Khz
Cascade’s = 38 Ohm @ SPL 100
Freq. range of 5Hz - 33Khz
HE6se V2’s = 50 Ohm @ SPL 83.5
Freq. range of 8Hz - 65Khz
LSA HP-2’s = 33 Ohm @ SPL 116
Freq. range of 10Hz - 50KHz
Elegia’s = 35 Ohm @ SPL of 105
T5’s = 32 Ohm @ SPL of 100
Freq. range of 5Hz - 50Khz
T60 Argon’s = 50 Ohm @ SPL 92
Freq. range of 15Hz - 35Khz
Hey Shane,
You’re welcome.
Your statement is true.
I struggle with similar problems.
The thing about Otl amps is that they prefer a certain ohm range and have their ideal working point there.
But sometimes they still don’t have enough power.
A classic example is the Feliks Euforia or Elise, which would be wonderful, work well but are just weak on the chest.
And they also have problems driving planar headphones even if they only have 30-60 ohm.
But doable,my Euforia amp needed a tube change to get where you want.
A Vcap capacitor rounded the whole thing up and made it better.
But as you can see it costs extra so it is suboptimal but doable and ready for it.
The Woo Wa6 seems to suit you better with all the headphones you own.
It’s also designed to handle low ohm headphones and drive with enough power.
Otherwise, this can only be done with a custom build where it is specifically mentioned.
Most tube amplifiers are not designed in this way.
If they are, there are very few where the Cayin also plays along.
If there is nothing in the description that says they are low ohmic operable, then pay attention to the output power at 32 ohm should be 400 mw the minimum.the higher the better of course so it also makes fewer problems.
I had my custom hybrid amplifier built there for similar money and am very happy with it.
You might have to wait a bit until it’s built.
You’d have to ask beforehand by email if it’s interesting.
