Hi guys.,
im looking for a good DAC (with PC-USB imput Jack), not expensive (< USD 400), that could do a good match with the “Xduoo TA26 s amp”
thanks for your suggestions
Equipment:
HD600
Hifiman Ayra
Ad900x
Hi guys.,
Equipment:
HD600
Hifiman Ayra
Ad900x
Budget? Most DAC’s from under $500ish will sound pretty similar.
I guess the Schiit modi multibit 2 would be probably be a good choice. The Hiby fc6 or cayin ru6 would be good portable solutions.
Not sure what the definition is there.
I have been enjoying the Topping DX1. It is under $100, with the latest AKM chips. I think the next really noticeable upgrade is the one @LakeWyles pitched, the Modi Multibit 2 ( at about $300 ).
Thx
something not too expensive = < USD 400
If your American then just get a jds el dac 2
