Hi my Korean friend wants a good speaker for under 200 dollars or so? Maybe up to 300. What do you recommend that is self powered and has a built in dac and stuff? Dosent need to be Bluetooth
This might be pushing it but the Kanto YU4 or Vanatoo T0 would be great. Something more in line with your budget would be the Edifier R1850DB. Or the audioengine a2
Also a few of those have optical instead of USB if that’s ok. If you really need usb there are cheap usb to optical converters.
Our YU2 is available at Sorishop in Korea. It has a USB DAC and is under $300 after conversion. PM me if you have any questions.
Thank you mon! Helpful as always!
Thank you kantoliving!
