Since i got my Koss 95x estat headphones and amp ive been a little concerned how im gonna transport it back home (im on vacay right now) etats are a little fragile. Was digging around Amazon and i found this for 25$:
This professional small hard case is perfect for protecting your equipment. It features an aluminum alloy frame with steel corners, side panels, reinforced construction, handle, 2 locking clasps, and 2 dividers. It also has an adjustable and...
Cant beleive its so cheap. its 13x10.25x5.12 it also has cubed sponge foam inside to easily make it customizable. Since so many of us got the Koss 95x without a case thought you might want to know about it. Also good for any other audio gear.
theres only 7 of these left (i bought 2 lol) but i found another one same company, looks like same thing:
This Professional Small Hard Case is perfect for protecting your equipment. It features an aluminum alloy frame with steel corners, side panels, reinforced construction, handle, 2 locking clasps, and 2 dividers. It also has an adjustable and...
Anyone know of a better case than these for audio?
Just recieved my cases today. they’re the perfect size for headphones. Lemme show you what i did with my Koss 95x
First i used a white marker to outline the headphone into the cubed foam, then started plucking out the cubes in the desired shape of the headphones:
They fit snug and perfect:
the case wasnt closing that well so i had to use a foam cutter to cut off some of the bumps:
After this it closed perfectly. They case also has a carrying strap for convenience:
And Rubber feet to put the case on the ground:
it also comes with some deviders for inside the case:
Now lets do the Focal Elex. Paid 700$ for this headphone didnt get a case for them. Thank you Focal.
I see that the foam from the Elex box will fit perfectly into the case i bought:
So i pulled the foam form out:
If im gonna fit this into the case i’ll need to pull the foam thats in it out:
The Elex box foam fit perfectly inside, i’ll have to remove the glue on the lid with some alcohol later:
Elex of course fits sung and protected:
j.fopps
November 19, 2019, 3:59pm
6
Wow what are the odds of that fitting in the case so perfectly
lol i know right? but i had the foam cutter if it didnt
Aspen
November 19, 2019, 4:50pm
8
Just get some fabric or a thin foam for the top case to make it look cleaner and 10/10
M0N
November 19, 2019, 4:51pm
9
Do you think you could modify the case to fit the energizer if needed for the 95x?
dont think so, its pretty snug, but maybe
