Sounds marginally better than my SMSL SU-9. Less fatiguing. THX 789 + GL2000 & Elear.
I didn’t understand when ordering though, that it doesn’t support MQA over USB which is annoying. That seems a bit deceptive. Now I’m not sure if it sounds “enough better” to keep with that caveat, since I’m not switching back and forth to jittery motherboard Toslink just to play Tidal.
. USB supports MQA full expansion decoding. C0AX/ AES/OPT/IIS supports MQA hardware rendering. Automatically recognize and render the MQA digital stream after the first level is expanded.
Aha. Figured it out. MQA only works with the Gustard X16 if you put Tidal in Exclusive Mode. This was not required with other DACs like the SMSL SU-9 and Meridian Explorer2.
