HeadAmp GS-X mini Balanced Headphone Amplifier/Pre-Amp
Yep something like this would be solid… I had a seller offer $900 with 2 extra op amps or $850 with no ops. If you look long enough you can find a deal.
What’s the general consensus between GSX-mini and Soloist 3XP?
I love my mini so I will shill the hell out of it. Also the power it outputs is pretty impressive.
Did you find an answer to this anywhere?
Negative.
Friend of mine is going to let me loan me his Soloist 3x in a week or two. I can compare with GSX mini then, but M0N has already given me a good description of what I should expect.
Been listening for about 2 days now. Impressions soon.
GSX mini vs Burson Soloist 3X
So I’ve been listening to both of these amplifiers to see what the fuss was about. And I think I get it now. Well, sort of.
Keeping in mind:
The GSX mini is an $1800 fully Class A amplifier with an optional $200 DACT attenuator upgrade.
The Burson Soloist 3X is a $1145 fully Class A amplifier with optional op amp rolling options.
I did all my listening using headphones via the balanced 4 pin XLR outs on both amplifiers.
I don’t think you should use these amplifiers single-ended unless you have to.
As far as power, GSX mini seems to have more power, especially at higher impedances.
Mini: 6W at 25 ohms, 4W at 50 ohms, 2W at 100 ohms (from HeadAmp’s site)
Soloist: 8W at 16 ohms, 4W at 32 ohms, 1W at 100 ohms (from Bloom audio)
First the GSX mini. The music sounds powerful yet smooth and controlled. The impressive technical performance is really apparent. The background is shockingly black with no music playing.
I think the amplifier is mostly very neutral sounding though it might slightly lean bright. I have not heard the GSX MK2 but some say that the Mini retains some of the signature brightness from the MK2. The amplifier is also quite holographic and full bodied. I really like it. When I first had this amplifier I compared it with my Topping A90 and the A90 sounded like a brick wall of sound in comparison to the holographic GSX mini. It’s probably not tube amp levels of depth or staging at this price but it’s still impressive. Not everyone wants to deal with tubes or distortion.
Now the Soloist 3X. With the default red Vivid op amps installed I liked the presentation the most. It wasn’t trying to outright impress me in its technical performance but it was more fun and laid back and surprised me occasionally with its dynamics. It didn’t have as much weight to music but was more airy sounding. It also retains that holographic presentation to my ears, which I believe people associate with Class A amplifiers. It’s not as bright as the mini, but I suppose that means it’s closer to neutral? It’s certainly not warm though I’m sure my Bottlehead Crack has skewed my perception of what warm is.
I wonder where this stereotype that “Class A amplifiers sound warm” came from. :thinking:
Anyways when I swapped to the orange Classic op amps, I could notice a slight edge to the music now. I wasn’t particularly fond of it to be honest. If you prefer that sound then more power to you, but I think it made the amplifier too lean sounding for a marginal detail improvement. The op amps also cost a pretty penny.
As a bonus, I swapped in some Sparkos Labs SS3602 dual op amps. Unlike the Burson op amps, you need to be extra careful to orient them properly or you’ll probably damage the amplifier. The Sparkos were quite different. They sounded very clean, wide, and detailed. Unfortunately this came at the cost of being too bright. Brighter than I was comfortable with as my planar magnetic headphones especially just sounded sibliant.
To my ears the Mini has better resolution, imaging, and fullness to the music overall. Partially due to more power I’m sure. HOWEVER, as everyone knows you really need to get into synergy balancing. The DAC I used throughout this comparison was the Schiit Bifrost 2 which some have called warm.
If the Bifrost is masking the GSX mini to seem less bright than it is, that should be accounted for. If you have a brighter, harsher sounding DAC you may prefer the tonality of the default Soloist over the GSX mini. As a rough estimate, I think the Soloist hit around 75-80% the technical performance and fullness on the GSX mini for my planars and 85-90% the performance on my dynamics.
I prefer the GSX mini more on my chain and I hope to upgrade my DAC and tube amp in the near future. (Holo Spring 3?)
TLDR
To my ears, you get what you pay for but make sure to balance the synergy in your audio chain.
The Mini was fuller bodied, brighter, more technically capable, and more powerful.
The Soloist was more fun, neutral, airy, and has the added benefit of op amp rolling.
As far as my preference:
For my planars the GSX mini was a clear cut above the Soloist.
For my dynamics the GSX mini was still the winner, although by a slimmer margin.
could you explain the mini’s technicalities over the soloist in more detail please? thanks for writing
Sure. Fuller body/weight to the music, blacker background, better sound separation, and higher resolution is what I primarily attributed to the Mini.
I have not heard the mini but I do currently own its older brother the mk2 and I mostly agree with your sound description and impressions. Crazy good amp that is so transparent and resolves like no other I’ve heard. It takes my Diana v2 and really pushes them to their full potential (or at least as close as I’ve heard them to their full potential).
Thanks for the impressions. I appreciate the instant buyer’s remorse of this morning’s purchase. :rofl:
Though I guess could cancel the order and lose $60. @M0N do you think I’d be just as happy with a GS-X mini? Or do you think my collection would have barely any synergy?
I mean I don’t know how I can answer that one for you lol. I think both amps would actually have somewhat synergy with your setups, although personally I do think with an 800s the mini can get a bit too far up there in treble. But it’s not exactly super fair since I think the mini would pull ahead technically and that will shift the deciding factor. But yeah unsure since the only one who can really answer that is yourself lol, I have no way of knowing what you may be happy with or unhappy with, I only mainly know for myself
Also @kcrack very nice write up :+1:
Sorry for being vague. Really I only care if there’s reasonable synergy between: Ares II, ADI-2, Clear, 6XX, LCD-2, and probably the Auteur later.
I happy using the 800S exclusively on tubes.
Thanks for the comparison. What headphones did you use?
Lcd2.2 prefazor
Modhouse T60 argon with alpha pads (nicknamed alphagon)
Hd800s
Zmf verite closed
Hd600
I briefly had Arya but only tested it out on GSX mini. Wasn’t a fan.
thank you for the quick follow up sir. some are self explanatory but could you elaborate briefly on those conclusions please? id love to hear more
Hi kcrack,
That’s a very interesting and somewhat surprising comparison. I had a GSX-mini for several months and never considered it to be bright sounding. The difference could be due to the DACs and headphones we use. In my case, I used a Chord Qutest DAC and Meze Empyrean headphone. I felt the Soloist might seem a bit brighter than the Mini, due to the outstanding detail & transparency of the Soloist. I also tried the Burson Classic op-amps, but preferred the Vivids. Anyway, I definitely preferred the Soloist to the Mini, perhaps due to my DAC & headphones. We all have different perceptions and preferences too. I’m glad that you are enjoying the GSX-mini. Regardless of one’s preferences, there is no doubt that it is an excellent amp.
Yes I largely believe the both of these amplifiers are very revealing and it will mostly sound like what your chain will allow your headphones to sound like. Don’t get me wrong, it’s not a glarey type of brightness that I associated with the Topping A90 or THX amplifiers. In fact before I had the Soloist 3X I was under the impression it was neutral. It’s just when I compared to the Soloist 3X I realized that my DAC was heavily influencing how I perceived each amp.
I mean, in theory both DACs and amplifiers shouldn’t really affect frequency response at all but we all know that is not the case. I just report what I hear.
Oh, and @Tommy I dunno what else I could add from here. I also kind of want to hear tubes again after listening to nothing but solid state for the last few days. :sweat:
oh yeah no problem sir! thanks for writing!
