I’m scratching my head trying to figure out if I’m potentially causing damage to my powered bookshelf speakers (Monolith MM-3) by using my JDS Labs C5D Headphone DAC/Amp as the go between with my PC.
The C5D is rated at max 2.0 VRMS. I suspect it reaches that voltage when using the high gain mode (which I don’t use). The reason I’m attempting this in the first place is because of typical bad on board DAC in PC with noise introduced with the line out. I don’t have a stand alone DAC on hand at the moment and want to see if I can save the money.
So the setup looks like USB from PC -> DAC/amp -> 3.5mm (amped) Headphone out -> Powered Speakers. The DAC/Amp doesn’t have an unpowered line out port, just a 3.5mm line in for portable use.
I’ve always read not to amp to another amp but in this case the headphone amp would be weak enough to be safe maybe?
