Saw this on Amazon not too long ago and thought it was awesome looking.
Yeah, I really liked it. Enough so that I have two.
I also have the one Martin shared above my post. It’s gorgeous.
The Room’s stand is for my main setup, and the one I posted are for my computer setup. They’re both surprisingly lite. At first I thought they were a composite, but after further scrutiny I concluded that they are indeed wood.
Had it already in my basket after your rec and I am going to get it later on
Nice. They’re really pretty, imo. But keep in mind that it’s more compact than the Room’s stand.
This is ideal, cause I plan to put it next to our bed with the Porta Pro on it
I Love it! The stand cost more than the headphone!
This is how you role - I just copy paste
My beige PP was 70 and the Yaxi Pads another 10…
so it’s about equal
Could you share a picture with both to see the height and width differences?
I forget the name, but the Walnut stand we’re speaking of is big enough for most headphone headbands that are narrow, but definitely doesn’t work With wide leather straps like Audeze, ZMF, or Meze (Empyrean).
It’s fine for Fostex, and Focal.
I’ll try and snap some pic’s later.
That is exactly what I need.
The Rooms is fine for Focal, Sennheiser and the Beyer and even your big Audeze
where are you guys getting your banana stands? everything off of Amazon uses a metal hook making them unsuited to adaptation for holding headphones. <_<
I have the woo audio stand. I like how it’s adjustable.
Could you share a link or picture?
Sure. I’m not home but this is it…
Woo Audio HPS-RB Universal Adjustable Height Aluminum Headphone Stands (Black, Single) https://www.amazon.com/dp/B006KLAM3I/ref=cm_sw_r_cp_api_i_qobwEbMQNRZE1
It’s heavy. Your headphones won’t tip over.
You can also get this one. It’s a double.
Woo Audio HPS-TB Universal Adjustable Height Aluminum Headphone Stands (Black, Double Model) https://www.amazon.com/dp/B006KLDWSA/ref=cm_sw_r_cp_api_i_gpbwEbQM0VF6E
Those are nice and practical.
