Headphones for movies,casual gaming and music
with a budget of 1500$, which would be the best choice for movies.casual gaming and music genres like rock,ost,classical
Do you have an amp or dac? If not, are they going to be included in the budget?
have seperate budget for it
If I had $1500 to spend on a set right now I’d buy either a Focal Clear MG or Radiance, but that’s just me…
What are you upgrading from, and are you willing to spend equivalent amount on source gear? When you start getting into that price range, the benefit you get tends to be limited to the quality of source.
I think my favorite headphones for movies is the Senheiser HD800s
