Headphones good for a tube amp for $250 at most new or used
I want to get the most out of the tube amp i got recently and want some good headphones for them
What’s the tube amp?
little bear b4x
Welcome! Decent little hybrid amp for the price to have some tube on the go. I thought the Senn 58X was pretty nice on it if you can get them where you are.
Also Sennheiser HD600, HD650, HD6XX.
Because you’re interested in tubes, I’d look to highish impedance headphones with a history of tube success. The mentions of the Sennheiser HD-6 series should be spot-on, without knowing any other desires about sound-signature and usage. Part is this reco, is that you may ultimately pursue OTL tube, which these cans will be beneficial with.
Because this is a hybrid-type tube amp, it will be rather easy to pair with a number of things. I do hope that it is sufficient for 300 ohm headphones. Those Sennheisers can also be run balanced with a new cable, which is likely a good idea to maximize this particular amp.
