I need a headphone for my phone. I dont want a Koss headphone but something else. I dont want to have to use an amp. Dont want IEMs, I heard of the Kiwi Ears Ellipse and it looks good at only 60$ But will it sound good without an amp? Any other headphones I should look into?
A used Hifiman HE5XX can be used with an Apple adapter for $9 and sound excellent and really comfortable. I also have the HE400SE stealth and it’s also tuned out of the box so we’ll. The AKG K371 wired is another winner that can be powered by anything and nice bass response in a closed back.
AKG K361 or K371.
The HE400SE is better than either of the AKGs above, but it’s a planar. It will work from a phone, but it sounds better with an amp. Planar drivers crave power.
A shame you don’t want an IEM. At the $100 price point, IEMs DESTROY over-ears in terms of sound quality. It’s not even close. The gap starts to narrow at around $200 and probably meets around $300-400.
If they want hp sound but hp size, that would be earbuds.
As for the apple dongle rec, If they are in europe, I would not go for it as it is volume limited (half the power 0.5vrms instead of 1.0vrms). Recommend Jcally instead, like the JA3.
You can do it for under $50. Pretty much any studio reference headphones will sound great: Budget Audio
Thieaudio ghost of you can find them.
Nank Ultra clip-on eabuds is fine.
Thieaudio Ghost is a interesting suggestion! I remember Zeos gave this a glowing review. But can a phone or dongle amp power it?
Yes it definitely can power them, they aren’t hard to at all but can scale up with gear.
Yes this doesn’t need any amp to sound OK. (Good sound without amp is too much to ask , isn’t it ? )
Simgot has sent me their new headphones to review. It’s a closed back and costs less than $100, to be exact $86. And well - of course it’s not perfect but it does more good things than bad.
I was worried about two things,
Midrange Bloat - which they suprisingly managed to avoid even being a sub $100 closed back. To keep in mind, due to reflection interferance Closed Back varies very much from head to head, acoustic impedance is bitch. and
Treble - I always said one thing, tamed treble is better than bad treble and they made it safe which is a good decision since it’s their first headphone and taking risk already made it worse for Kiwi Ears as we have already seen. (Like in 2-6Khz its smoother than HD600)
So, Midrange & Treble is not bad. Which in itself a pretty big deal under $100, that too for the first time & that too being a closed back.
Now, I was expecting two things and it delivered that.
Bass - For the most part, the bass is good. The dynamics are there, not anemic / good depth / a bit textureless though.
Soundstage - Performed exceptionally well, I have zero issues with the stage as of now. Round / Holographic / Trackable.
At the end, there is always something that reminded me this one is a budget headphone.
Detail retrieval is not the strong point of this headphones. It is not that resolving to begin with and the treble safeness makes it even smoother.
The next thing that bugged me was the swivel on the cups, they are non existant. Why ?
Anyways , after a few hours of testing I read that they were made for gaming. I am currently playing Uncharted 4 and RDR1 on PC, will upload the whole review on 28th. Bye
