My right ear is 10-5% less sensitive (?) -Im not sure what the correct term for this is- and im looking for advice on how to balance/center everything. Hope this makes sense and sorry for any grammar mistakes.
I use a old kef instant theater thats connected to my laptop via 3.5mm (im working on finding a better connection) and for headphones (Sennheiser HD599, Beyerdynamic dt 770 PRO 80ohm) i use a Audient iD4.
Cant believe i forgot to add that in my original post haha
stay safe peeps
What equipment you have? Source, amplifiers or dac etc.
Living with headphones or speakers?
Basically methods are somewhat similar and can be done with many ways.
Edit;
Was not even thinking the option with hearing aid, would that be possible to balance it out that way?
There might be a Calibration menu to adjust channel balance?
So you would hear, singer being at the center position. Increase right side speaker volume + right surround the needed amount. If singer now is more to left side.
Kef Audio Instant Theatre Kit100
Calibration Menu
The standard settings will already be correct for a normal room.The calibration menu allows you to test that the speakers are all connected and allows you to adjust individual speaker levels if required for your individual room. Note: The calibration option will only appear if you are in âdisc modeâ when you press SETTINGS.
*Sitting in a central seat of the listening/viewing area, go to disc mode, highlight and SELECT âCalibrationâ to start the acoustic calibration process. Noise will emanate from one channel, then the next, and the next, right around the listening/viewing area. Use the up/down navigation cursor keys to adjust the volume of any channel that doesnât appear to match the others.When all channels sound equally loud, press STOP or EXIT on the remote to exit the menu. * It is recommended that a Sound Pressure Level meter is used to measure the sound levels accurately. (Although it is possible to adjust the subwoofer level during this process, KEF recommends only confirming that the subwoofer is working, but not attempting to match its level to that of the other speakers. It is best to make fine adjustments to the subwoofer level using the remote control keys during normal listening.
Sorry if all the answers seem so obvious to you all, but i seriously havent thought about getting hearing aids. I need to do some researching now haha thanks for the advice
Brains do compensation but it wont or canât fix a loss/lowering in specific âfrequency range/rangesâ, where the personal issue might be. âcannot recover speech intelligibilityâ
As example. âHissing or static noiseâ or just speech with low/normal level volume, you might detected sound with left ear but not with the right. Depending of course what is the âlevelâ of damage in what FR-range.
Some might not even notice a thing in daily bases but with, low or normal levels and really focusing, you might notice things like. Center imaging is off by a touch. To the range of -30db loss in specific FRâŚ
Like in the audiogram / beep hearing test or someoneâs voice is in the range, cannot make out what other person is talking if being on bad hearing side.
So some personal DSP or EQ adjusting will help alot, if equipment or settings allow.
