The following are the only ones with affordable shipping to my country. They vary from being dirt cheap to relatively expensive:
I appreciate any and all help. Thank you!
I have personally used a variant of the first driver in a closed headphone and quite like it. But to start out id recommend trying the Tymphany HPD-50N25PR00-32. Its pretty cheap and commonly used. It also is fairly easy to tune in my experience.
Look if DigiKey for example sends to your location.
Ive also tried some 40mm drivers from AliExpress but have not finished anything so I cant attest their workability.
The others you have linked may also work ofc but I have no experience with those and the ones with a complete baffle may make it easier but also more limited how much you can try out and tune a driver
