This has been driving me insane. In short I want to find a 3.5mm female to 3.5mm male right angle that is 10cm-15cm (or about 3 to 6 inches). There are results on Amazon, but all I can find are obscure Chinese-branded stuff with questionable QC and build. I don’t mind paying a slight premium but I really just need a short extension/adapter… Don’t care if it’s cheap rubber insulation as long as it actually works.
If not, I think 1.5ft (~45cm) should be fine too.
As for why I need such a specific length… my ATH-EW9 has a 0.6m cable which is just 10cm too short to be used with a phone in my pocket or with my Magni on my desk. The included 1m extention is pretty unweildly since it likes to coil on itself. I also plan to get a Shanling M0, and 10+cm is also what I need to be able to connect to it if I strap it to my wrist.
Thanks.
