Help looking for new headphones want upgrade from Sennheiser Urbanite xl
I would like help looking for a new pair of headphones with a 700 dollar limit I’ve had my sennheiser Urbanite XL for about 2 years they’re still in good condition I just want to upgrade.
What kind of music do you listen to, and would you be using a dac/amp? Also would these be for portable and be closed?
I listen to mostly listen to lofi, classic rock, rock, edm, and sometimes hip hop/rap, I have a magni 3+ for an amp for my turntable but I also plan on using them on my phone and ps4. I mostly used closed back headphones but I wouldn’t mind trying some open back headphones
Gotcha, well you do have alot of options, I would personally say stay under 300, as imo you don’t want to jump too many levels for the upgrade. What type of signature have you found yourself liking? What do you like about your sennheisers and what would you want to change?
I was doing some research and I thought I would like to try some open back headphones since their mostly for music. And what I like from my sennheiser would be the clarity of the music and the atmospheric they felt when I first got them since they were the first proper pait headphones I’ve had. And thanks on the advice for staying under 300
Ah, well if you wanted a good all rounder with a very open that is very detailed and impressive the hifiman sundara is pretty sweet, works well with the genre you mentioned imo. Also a pretty nice pairing with the 3+ as well. If you wanted to stick with sennheiser, you could grab a hd660s (for hopefully a good price used) which would be solid
Thanks for the advice
