what amp/dac do you think is best substitute for chord mojo?.. what is the best possible option besides mojo? that can also drive a 600ohm headphones and is compatible with mobile devices?
Does it have to be portable? If so, iBasso DX160 is a good choice. Very similar sound signature to Mojo IMO but with more soundstage. Itβs $400 (Chord Mojo is $500).
Itβs fully balanced, also. For it to handle 600ohm, youβd better use the balanced output.
Unfortunately yes, i travel a lot so portable ison my priorityβ¦
alright iβll look into this, iβm hesitant to purchase mojo because of the heating issues and the reviews on other forums and guides are not all that good. thanks mate!!
