Hi, hello…
Just looking for some advice on how best to integrate a Schiit Freya tube pre into my 2 ch & headphone setup.
My goal is to get a taste of that tube goodness on my headphones and speakers whilst using the DAC in my Jot as well.
My post is really concerned over these two questions: what should I do with the Jot Pot - do I leave it all the way up or fiddle with it until its loud enough post freya & is there a way for me to get a fully balanced headphone connection with tube warmth out of my Jot?
I think that won’t work as I’ll be trying to use the USB input and a feedback input from the Freya at the same time.
Power amp for speakers is an emotiva XPA2.
Signal chain, I am guessing, would look like:
Speakers: PC via USB -> Jot via XLR -> Freya boa XLR -> power amp.
Signal path for the headphones would probably be essentially the same I think.
