What about an AKG K701 for $80?
Hmmm thatās a pretty solid deal, and would be able to run ok out of a solo interface
Ye, if i read it correctly its pretty much the same as the k702
Itās a bit different, the 702 is a bit more full/warmer sounding than the 701, the 701 is a bit more lean/dry in comparison, also no detach cable as well
How much of a difference is there between a 32 ohm and 600 ohm version? Can you quantify it? A lot of people want a lower impedance for these headphones and im not sure if its a good idea.
I really am not a fan of the lower ohm versions, I think that the 600 ohm is most likely about imo 20%? better than the lower impedance in terms of detail, refinement, and coherency vs the 32 ohm assuming you have a proper amp for the 600 ohm
if were going to run a headphone off a interface I feel the hd 58x would be a better direction personally guaranteed to work and is a good allrounder and is one of the best in gaming for its price bracket.
though the akg k701 for $80 isa good deal definitely better than the superluxās but I dont really think the superluxs sound good at all personally so most things are an upgrade
I would be inclined to agree here, the 58x is fairly solid as well
I think the k701 at $80 is a good deal, and will be quite nice for gaming. For music Iād lean more towards the Beyers - plus, I like their build and fit better. I wasnāt a fan of the 58x myself, but I seem to be in the minority on that.
If i go with the beyerdynamic i probably want the higher ohm versions, for those i need a new amp, i cant really afford both, running them from my steinberg is not an option unless i find one low ohm version used, which is next to impossible.
So many options and i cant really decide
Tyranny of choice. Welcome to the headphone world. Just gotta jump in and see what you like. Like several people have said those AKGs are a good deal at $80. Iād say try them and see what you think.
One more thing i found
Akg k612 for the same price as the k701, which is better?
For gaming? I would personally prefer the 701, for music I would pick the 612
