Can someone help me please, I can’t decide between the SMSL SP100 and the Sabaj PHA3 , I’m want to buy a tubey affordable amp.
Is there any other good option below 90 dollars?
I have a Topping D10 DAC and the AKG K712 pro.
I’m leaning more for SMSL because I trust Zeos review.
I can’t comment on either, the issue you’ll run into at that price point, for none Hybrid designs is power output.
Your AKG’s are also not going to like most pure tube amps they’re only about 60 Ohm Output impedance.
Maybe consider a tube buffer before whatever amp your currently using.
Being that small, cheap and without a big transformer, I’m pretty sure both amps are hybrid, and im ok with that.
