I would say so yes
I own a pair of the Kali lp6’s. Awesome monitors… Low end can be unbelievable. easily adjusted by switch. Absolutely love them!
you use them nearfield right?
Yes. I have them on Kanto 32" stands with the dip switches set for my home office/goofing off room. I currently have them connected to a Jotunheim but going to change to a Asgard 3 this week. I was going to connect a sub but I have found it is DEFINITELY not needed.
I also found the dip switches on these are really easy to do to customize… easy to set for your room acoustics/ positioning.
