I need a bit of extra storage space in my room to hold some basic stuff. So I’m looking for a short multi level shelf/rack to hold equipment like an amp etc. and was wondering if anyone had suggestions. It cant be more than 25 by 25 inches unfortunately.
Been thinking about modifying a bunch of ikea lack tables into a multilevel shelf.
I’m not sure the size of equipment you’re using but I use this stand for my Desktop setup. Fits modi, Magni, liquid Spark Etc. Look at the customer photos at the bottom
[Topping stand](Topping 14x14x4.5cm for A30 D30 Amplier Shelf Transparency https://www.amazon.com/dp/B01NCZQ0ZZ/ref=cm_sw_r_cp_tai_mV5ODbTW81E4Q)
For my headphone I use [Folding headphone holder](Geekria Foldable Wall Mount Headphones Holder, Headset Wall Hanger, Aluminum Wallmount Hook, Hold Up to 1kg with 3M Tape, 20kg with Screws, Stand Come with Headband Protective Pad (Black 2pcs) https://www.amazon.com/dp/B078VMFQ46/ref=cm_sw_r_cp_tai_jZ5ODb1YDANJR)
These are cool but I am unfortunately looking to hold side equipment a fair bit larger.
Wacom tablet, Color correction wheels, cinema camera, 2 channel power amp
Edit: I might get the topping stand as well.
Yep, looking for something exactly like the Topping acrylic shelf, but big enough for a Bifrost. Anyone…? I can’t find ANYTHING
I double stack these below my monitor and it gives me a good amount of space to play with:
Nice setup. Way too big for me, though.
SANUS A/V bases have worked very well for me. They hold allot of weight, relatively cheap, solid build. fit your size requirements, and you have multiple options for number of shelves if you mix and match a unit or 2
