Hifiman Arya Organic vs. Arya Unveiled: Which one should I get?
Hi everyone,
Thanks in advance for your help!
I’m currently trying to decide between the HifiMan Arya Organic and the Arya Unveiled. As for a DAC/Amp, I’m currently planning to buy a FiiO K13 R2R to drive them. My primary use case is general daily desktop use—a mix of gaming (including competitive games), movies, and music.
I’d really appreciate your experience and recommendations. Ever since I sold my Sennheiser HD 700 five years ago, I haven’t been truly satisfied with any setup. Back then, I could pinpoint enemies in games with incredible precision, almost like I had a radar. I haven’t found a single pair of headphones since that delivered the same level of satisfaction.
Do you think either of these Arya models can fill that void? Also, if you know of better DAC/Amp alternatives to the FiiO K13 R2R for these headphones, I’m completely open to suggestions.
Or do you think nothing short of an HD 800S will make me genuinely happy again, and I should just go straight for that instead? Budget isn’t an issue, I just want to make the right choice.
Thanks in advance for your insights!
