Yeah, Openheart cables are pretty good. I bought one for my IEMs, and quite like it.
I actually bought the Openheart knock off Grado (its actually an ok headphone if you mod it), but the cable that came with it is rather solid i use it for my Harmonicdyne Helios. But I treated my Edition Xs to a more “heavy duty” , Tripowin, a very “thick” cable, very nice weave
I also have the tripowin granvia (Amazon) . Got for my Sundara and like it.
Grabbed a Senn 800 model from Linsoul during one of the megadeals. Purple to 3.5mm and it’s great. I don’t completely mind the stock cable, but it’s just too long and heavy for desktop usage. The build/color/lightness exceeded my expectations. Not weighing in on sonics.
All NMD Custom Pads are treated with the finest leather conditioner.
Howard Leather Conditioner:-
Unique blend of deep nourishing moisturizers and natural waxes helps keep leather goods looking and feeling like new.
Revives dried-out leather back to its soft, natural condition without becoming oily or sticky.
Creamy lotion like conditioner that penetrates, preserves, and protects smooth leather.
Conditions with lanolin, neatsfoot oil, coconut oil and aloe vera - Protects with Brazilian carnauba wax and beeswax.
Helps leather resist cracking, scuffing, and dry rot.
#NMDCustomPads #HowardLeatherConditioner #CareForYourPads
To know more, please visit:
The Most Selected, Type B.
Inner Perf. Suede with Suede and Soft Lambskin.
Experience pillow-like comfort with slow rebound memory foam.
Sonically + touch of rumble and warmth to the lower octave while enhancing the soundstage and separation.
Listen with comfort.
#NMDCustomPads #ListenWithComfort
NGL I definitely want to try these Ntrax pads out. But I’m just cheap and bought some from Ali instead, I can’t tell much difference in the sound. Sorta hard to A/B test but I can’t tell much difference from stock, but they’re comfy, so overall I’m happy since it was pretty cheap.
Thank you for your interest. All NMD pads are full custom, size, cavity, thickness, color, material.
You should just figure out which ones measure well and do a larger run with lower price tbh, I’d bite in the 100s if I know they’ll work well but you’re more than doubling dekoni and over 10x the ali ones, it just makes no sense for headphones priced $500, maybe for like a he1000 or a susvara…
I’m not against any other sources for pads, infact I always advice ppl to try out the most affordable first before splashing real budget into it. This is the correct way to play audio.
I’m just here for options to those truly feel uncomfortable or need to express their own creativity or preferred ideas on their very own pads. In short create their own signature pads.
Are you having a Black Friday sale this year?
Yeah but what I mean is that if you’ve found a formula that works well for a specific model you should just do a larger run
I could do that…that’s great. But may I know when? Hehe. I’m not really following all these sales event, so appreciate if you guys could throw me some date on coming sales event.
Not really a retailer but share some creation while myself trying out multiple configuration. Yeah I do get a little profit here and there but not my main objective.
Due to custom work, the pricing will be about steep. Maybe I can work out a group buy instead too. Any suggestions will be great. Thank you to you all anyway.
Black Friday is November 25th this year. I’m sure most people who see your products appreciate that it’s a premium product. But with a little dip in the price they might bite, Good luck with sales!
The Type B actually is the most recommended pads configuration. I have a dozen sold and all positive feedback. Only 1 wanted more thicker because the stock pads is too shallow for his wide ears. So made 1 and return buy another.
Thanks man…will definitely ready for it. I think I may need to pre made plenty to lower the price even more.
Btw I do give discounts when someone ask and really ready for it. Discount 5 to 10% sometimes.
Here is a brief comparison of the 2 most asked NMD Custom Pads vs Stock Pads.
Measurement was taken with The MiniDSP EARS - RAW: No headphone compensation.
did you try the headband from aliexpress on the edition xs ?
It won’t fit. Nothing fits the XS. I’m not sure but maybe only the Ananda/Arya headbands may fit, that too if the holes are right (for the Arya). Since I have that older headband on my he400i, I can see that band requires larger holes on the cups, much larger than XS, Ananda headband.
Anyhow… Personally, I wasn’t looking to change the headband. I’m quite satisfied with it. But for any folks that are, I don’t think there’s much to do here for them.
