šŸ”¶ Hifiman Edition XS
That is a sweet headphone. I have the HP-2 which uses the same driver and it’s fantastic. I think the GH50 is a slightly better overall set.
I really enjoyed it, definitely a different presentation than other closed back cans of heard but sadly they are onto a new home.
Something I find odd is that Hifiman tends to revamp their models a lot. Look at the Ananda and Arya. Could very well be an update to the Edition XS coming. They don’t need to change the tuning or anything, just fix the headband and it becomes the new king.
First we’ll get Edition XS Stealth, then Edition XS Nano, and finally Edition XS Organic!
@InvisibleInk
You mean: Edition XS Stealth Double
:grinning:
The OG already has stealth magnets :sweat_smile:
It could def use a better headband, sure. Wonder what we, the existing owners, should do though.
a concern I have is that if you start scaling the quality of your headphones before you scale the quality of your sound chain, you’re not going to get the expected performance from your cans…in fact, you may form negative opinions and wonder why others speak so well of a particular set because they didn’t sound special in any way to you.
to illustrate, you wouldn’t buy a Ferrari only to swap the engine out for something a lot smaller and impair it’s performance. you want to drive it, race it, let it hit its stride and enjoy the experience…not putt putt putt.
I was under the impression that amps and dacs are largely placebo besides the power capabilities of the amp and some perceived tonality changes which is why I say I am fine with the atom stack until it can’t run something I purchased. It is also known to be clean and neutral which I am a fan of. Please correct me if I am wrong.
If you are happy with your setup, then that’s great!
I liked to experiment. I found a little color suits my gear. The Magni
Piety was the thing, and Sony DAPs.
it’s definitely not placebo for amps though it’s more nuanced for DAC’s and nuanced for amps when you get up to TOTL parts. for instance, my Zen CAN cannot drive my HE6se v4 so I haven’t gotten to enjoy them yet. while I got them at a screaming price, these used to be $3000 headphones and the recommended amp is an integrated amp that sells for a grand. they need power in order to perform. another example would be electrostatic headphones. the more power you feed them the better they sound…but if you put high end estat’s on an entry level energizer, they’re no fun because they were not built with a lower end sound chain in mind. it doesn’t make sense to drive $5000 headphones on a $300 energizer…nor does it make sense to use $700 estats on a $3000 energizer…even though the $700 estats would really sing if you did that. :wink:
Yeah I wasn’t really looking to go up a tier exactly and more so just looking for a different flavor that could potentially be an upgrade as it is in certain aspects. Otherwise I would just go Arya/HE1000.
The only reason to upgrade the JDS Atom stack is if you need more power to equalize and still stay in low gain for best performance after a preamp reduction. I’m using a Topping A70Pro/E70 now and the last JDS Atom+ stack was just as impressive sounding, just not as much power of course. I used the Arya Stealth on it and it sounded great (I don’t equalize that pair so it’s good). I get stuff for the business all the time, and these Hifiman Deva Pro wired are my new daily drivers, really impressive. The Ananda Stealth was a good job updating from the original, but the Arya Stealth is the best headphones I’ve heard. They re-tuned the upper mid shoutyness from the original and perfect for me out of the box. Deva Pro Wired is hands down my new winner in value for money, improvement over the HE5XX which was my daily driver for a year.
hi hot, I was trying more to point out that if you upgrade your amp, and perhaps your DAC, you should expect much better performance from your Edition XS…something similar to what you experienced the first time you listened to good cans and started to hear things you never did from music you knew on a personal level, only to find you really didn’t. it will be a bit more nuanced, but if you have high quality music to listen to, it would refresh all your headphones. perhaps look at some of the newer amps from HFM…there are several I dream to demo!
Not to get too far off the track, but I can vouch for upgrading the chain. The gains can be pretty dramatic; they were for me. That said, we all know the dangers of going down the rabbit hole. We all need to figure out what we want to get out of this crazy hobby and apply the required discipline!
As for the XS, I am not sure we will see a next version of it. They have a good enough product line that they can evolve those. This one did its dance. I was pretty negative on this headphone for build quality considerations, But they were having a sale…
Bottom line, the build is crap, they sound amazing, and I’m glad I have 'em. That said, I would not replace them if they were to ever fail.
FYI for any Edition XS owners that hate the headband and haven’t modded it. I got the Capra Audio comfort strap and it sent these cans through the moon. I loved these for a while now as one of my dailys but now they are soooo much better.
Excellent to hear. I still use my set quite a bit but like you I hate that headband. I got a pad for it and it helped a lot, but I took it off and put it on my new set, the Horizon Closed Carbon. I may try the Capra now, as I can’t even deal with the thing stock. Thanks for the report! :+1:t2:
That XS headband caused me to chose the Ananda SE!
To me they sounded like very close cousins.
I modded them 2 months after a got them, never looked back :smiley:
All this talk of the XS made me put my new ones down and give the XS a go. I’ve got this funky off-brand Silver Litz balanced headphone cable on it which ends up sounding fantastic on these cans. Liquid Platinum is the amp of choice. Great pairing. These things are really good. Very pleasing experience.
Just bought a pair of Hifiman Edition XS as my first ā€˜audiophile’ critical listening headphone. I’ve owned a pair of Moondrop Kato IEMs prior to this and have an E10k from Fiio that a friend gave me as a gift a few years ago. I should have them this week so I’ll give my review once they arrive and I’ve broken them in.
Currently my go-to headphone is a pair of Corsair Hs55 wireless. Looking forward to the huge leap in quality. Only ever experimented with a friend’s pair of dt990s previously.
I’ve also got a friend 3D printing a strap for the headband. I’ve got a smaller head so I’m a little nervous about the size of the earpads.
Congratz the XS is a fine choice :smiley:
Quick question what are you powering it with? the XS is more power hungry than most gaming headphone
