đŸ”¶ HiFiMan Sundara
I was just going to say, I have noticed the same thing. I have moved the Sundara into the bedroom system, using the V40 to stream AMHD over LDAC. Because I am using the mobile app, I have Atmos content available, and I have noticed the difference the Atmos makes. I really enjoy it. The Sundara is an incredible fit for this system.
Merry Christmas to you and to all.
Not sure if anyone is mildly interested but I got curious and bought both a Sundara and a HE400se and swapped the headbands.
The swap took about 15 minutes.
Hi, how do the screws work for these? I’m looking at replacing the headband for a potentially broken pair of sundaras but I’m not seeing a screw head inside to attach the outer screw to
When you unscrew the bolt you an see the thread which is inside the cup. There are washers between the screw and the arm and another between the arm and the cup.
I was setting up for tonight’s session, and I spied the Sundara out of the corner of my eye. I haven’t listened to the Sundara in a long time, so I thought I would have some fun with it tonight. I dusted her off, connected up the HE1000 cable, which for whatever reason turns out to be a great pairing, fired up the Liquid Platinum, and went to work!
I had forgotten how good this headphone is. Don’t get me wrong, I’m not going to try and compare it to the Radiance or the HEK etc., but the Sundara is a very solid set that provides a fun and engaging listening experience. I have always loved the look and the comfort of them and if felt good to have them back on. They presented very neutral and flat initially, but after a little brain burn-in the dynamic range started to come in. I have always loved how this headphone presents vocals; slightly forward and incredibly clear. Since all the EQ profiles I had for this were obsolete due to equipment changes, I scrubbed them and bult some new ones, and now have great baseline profiles for the Liquid Platinum and the SA-9, though I think this will live mostly on the LP. I love to tinker with this kind of stuff, SO I had fun creating these new sound fields. I am surprised by how receptive the Sundara is to EQ. I find that I am able to really dial these in with the Peace APO and really get the best out of it.
It’s been a great time re-discovering the Sundara. Again, not a world beater, but a classic looker and a very solid performer. I have thoroughly enjoyed tonight’s session with them. They are joy to have in the collection.
@Raptor168 Amen! Still enjoy mine
and agree with the clean, forward vocals.
I seldom eq, but I like to add in a bit of low end to give them more body.
I passed my Sundara along to a friend to get him into the hobby, and he is currently enjoying them hooked up to a Magni & Topping D50s. I do admit that I miss them for some genres of music, but I am glad that they are getting used on the regular. Out of the headphones that are currently on my desk, I would say that the Starry Night V1 has taken its place for that use case (granted the Sundara still does some things better).
I have the habit of passing audio gear and PC parts along to friends and family who can make use of them. :wink:
Hey, I need some advice regarding cables. My stock cable has contact issues, so I got 2 different third party cables, an open heart from aliexpress and another one I picked up at a local hifi store which should be pretty decent. Trying them I’ve noticed that with either one of them, there was an extreme amount of channel imbalance that wasn’t there when I used the stock cables. I can still get my old cable to work at the right angle, so I double checked, and yep, the difference was instantly noticeable.
So what’s causing my issue, is there a way to solve it, and if not then how do I get a cable that works?
Hifiman Sundara review: Like a magnifying glass. Too bad it’s also magnifying the treble (might be fixable with pads, but good luck finding “the one”).
Let’s start with how they look like: There’s a lot of metal. They look and feel solid. They feel like they’re going to last decades. Hifimans being hifimans, they probably won’t. But oh well. They look and feel like high quality stuff. Just don’t throw em around.
After Nad HP50’s, HD6XX’s, and Fostex T50RP’s, I wanted to try something else. Better planars. Something a step above all I had. TL,DR: This is quite it. There’s an impressive amount of sub-bass, for open-backs. These obviously can’t beat T50RP (closed-back planars) for bass quantity, but if you like bass and have to choose between HD6XX’s and these, well there’s no question. I can confirm planar bass just works, doesn’t matter if they’re open-backs or closed-backs. They’re a step above all I got in details and they’re a step above in the mids too – there’s a ton of information. They also got too much treble to sound neutral to my ears (especially considering they’re open-backs). Good soundstage width too, but with the original pads, they’re lacking in soundstage depth. Sundaras also appear to have exchanged dynamics for compression, for the sake of detail. I’m not complaining, it’s a different, interesting approach. Yes, they’re very detailed. Still, despite all that, they’re not at all “neutral, analytical, mechanical and boring”. I repeat: Not at all.
Test was done with my XDuoo XD05 Basic DAC plugged into my Aune X7S (Class A) headphone amp.
Bass, mids, treble.
First: Definitely do NOT underestimate what very worn-out pads can do to Sundaras. I bought these Sundaras used, with very used pads. I plugged em straight into my XD05 Basic and activated the bass boost, enjoying them for hours and hours. Then I received these inexpensive pads. If I did not gain 5dB of bass and sub-bass, well
 it might be 10dB. These are definitely my first open-backs to pass the “UDM - Oblivion” sub-bass note test (at 0:55) – yes, without any bass boost, just
 correct earpads. My HD6XX’s or Nad HP50’s don’t pass this test. My modded Fostex T50RP’s hit like a truck, but yeah, it’s closed-back planar bass (and, basically Fostex’s signature). Def Leppard - Pour Some Sugar on Me got a decent amount of bass frequencies too, and the drum kicks, as they should, kick your ass.
Mids are all there. Joe Bonamassa - Walk in my Shadow sounds impressive. Instrument separation is great. Planar speed is apparent, without getting in the way of the music’s naturalness (these do not sound sterile/mechanical like Fostex T50RP’s sometimes do). Do these give me the most natural, life-like mids of all I have? Probably. Sundaras mids got such an impressive amount of depth and information. And remember, I own HD6XX’s
 Too bad Sundaras mids are more often than not “veiled”
 by their treble.
Treble is all there – and more. Too much for my treble-sensitive ears. Treble can be problematic. And there’s also too much treble for just anyone, treble-sensitive or not, for em to sound “correct” : Timbre is off. Hifiman treble is known for all the good and the wrong reasons. There’s no treble peak whatsoever, but these are just very clear-sounding headphones. Sound is just tilted towards ALL the treble, from the high-mids to 20khz+. Motorcycle - As The Rush Comes (Gabriel & Dresden Remix) is basically sibilance city. If you have a bass boost switch, it can help. Still, its treble can annoy. The little piercing, overly sharp overtones and harmonics are, most of the time, not annoying. But you’ll KNOW they’re there, and these treble-oriented headphones will ALWAYS remind you they’re there, ready to make any damn recording which is slightly brighter than the norm terribly annoying to listen to (yes, these headphones are the enemies of 128kbps mp3 cymbals).
Long story short? Hifiman Sundaras feel like they’re “tilted” from -2.5dB at 0hz to +2.5dB at 20 000hz. They’d be endgame if it was the exact opposite – especially for open-backs.
Technicalities
The technicalities remained the same, whatever the source. Even when I tried em with a tube amp, when tubes (or the impedance mismatch) smoothened the treble, all the detail was there. This means, this is not “fake detail”. The treble-oriented-ness was not needed for Sundaras to sound detailed. They did not need to cheat. These are quick planars and every detail jumps at you. Everything is there. Compared to HD6XX’s, Nad HP50’s, Fostex T50RP’s, or my Hidizs MP145’s IEMs, these are less dynamic (i.e.: these don’t punch as hard). They’re compressed (i.e.: the difference between the loudest and the most subtle sounds in songs is smaller – therefore you hear more detail). The planar “version” of Koss ESP-950/950’s? Probably (I don’t own these
 yet – but apparently they’re electrostatics with a “compressed” sound). It seems like the Sundaras exchanged dynamics for compression for the sake of details. An interesting, different approach, resulting in an interesting, different experience.
Case in point, well, everything in Tom Waits - I hope I don’t fall in love with you.
Mark Sandman - Early Man is uncanny valley territory, despite all the hiss in the background. It sounds as if the hiss was added over an excellent recording only for “artistic effect”.
For speed? These also pass the “Fleshgod Apocalypse - Pathfinder” test. This song is very fast, and very demanding, and will sound like mud in a lot of headphones (and speakers). Here? Perfection. It’s like the Sundaras tell me there could still be space for more instruments.
Parenthesis: These got to be the most “perfectionist” headphones I’ve ever heard. I swear moving them up, down, left, or right on your ears for “X” millimeters will affect the frequency response “X” decibels somewhere. Want 2dB less treble? Move em 2 millimeters to the front. Yes. Both a plus and a minus: These take time to set perfectly on your head, but you can choose how they’ll sound – much more than any other headphones I’ve had (there will always be too much treble, though).
The downsides of a “compressed” sound.
A compressed sound means you’ll always reach for the volume knob to hear more, if only because you’re used to the louder things “hitting” harder, and want to “rock” at the same volume than usual. But instead you’ll get
 kind of a wall of sound. Leave this volume knob alone! You don’t need that much volume anymore: You already hear everything, just at a lower volume level than usual.
Soundstage width is ok, but doesn’t have much depth (in front of you) though. It’s “eye-shaped” soundstage. There’s great, great instrument separation. But add said “compression” to that, and it also means the “perimeter” in Gidge - Perimeter appears way smaller (1:30 onwards paints a 20-foot-wide sphere with floorstanding speakers, with no care about if there are walls around the speakers or not, for example).
Compressed headphones means differences in dacs and amps are also magnified. Meaning any neutral or “crisp and clear” source will be a dice roll. The pairing might not give you life-like timbre, just something treble-oriented. Get anything “tubey”, Class A, and/or with a laid-back treble. Otherwise timbre will be off (Saying it again: They feel like they’re “tilted” from -2.5dB at 0hz to +2.5dB at 20 000hz. They’d be endgame if it was the exact opposite – especially for open-backs. Therefore if you get any dac/amp making em sound even more treble-oriented, this won’t be good: Your “darkest” source is your best bet to get natural, life-like timbre).
Final thoughts: A very musical, very enjoyable “magnifying glass”.
What can I say. Bass is decent. Great for open-backs, “because planar”. But they still kick way less than the recent, harman-tuned stuff, because they have the pre-2020 harman
 bass canyon. Mids are top-tier. Detail is top tier. But treble is too much – always. If you want details above all, this is for you. If you listen to a lot of music and movies and videos and often wonder “what did they say?”, this is for you. If you’re getting old and lost a bit of the treble you used to hear, this will bring it all back for you. Often, “gaming” headphones (actually made for gamers, not the plastic ones sold on Amazon with flashy RGB leds and disposable drivers) are a bit treble-oriented because it helps you hear footsteps. I don’t play Counter-Strike/Tarkov/etc., but I reckon these can give you an advantage. They’re both compressed AND treble-oriented. Meaning Sundaras will kind of give you superhuman hearing.
Superhuman hearing? So, hmm, why don’t I give em a glowing review like, pretty much everyone? Well, superhuman capacity to hear everything but especially in the treble region is the worst thing for me, and that’s what Sundaras do. Because I already got this superhuman power, and I hate it (lol). Also, on hifiguides, I heard a lot of times that “open back headphones were the way to go”, because closed-backs were full of “compromises” (?). That’s weird, because I always thought it was the opposite: I always preferred closed-back headphones. Most music is obviously recorded inside a studio room. Open backs
 never give me the impression I’m listening to a closed room. Open backs give me the impression the studio room moved outdoors (somehow). This is even more flagrant with these treble-oriented open-back Sundaras. It’s as if they’re artificially “removing the ceiling” of studio room recordings.
Yes, I’m treble-sensitive. Yes, I’m a perfectionist. But that’s what being an audiophile is, basically: The search for perfection. If your headphones (or tweeters) are not as good as the “what kind of sorcery is this”-level of my Emotiva B1+'s EMT Tweeters, lower the treble by 2 or 3dB or, like the Sundaras treble, I won’t tolerate em much. If Rabbit Junk - Precipice (basically a treble torture test) hurts my ears on any headphones or speakers, this is not good enough for me. Still, if you don’t listen to music (too) loud, if you’re a casual listener who doesn’t sit like me with my headphones on for a minimum of multiple hours, yes, these headphones will be both a very musical, very clear-sounding, and very enjoyable magnifying glass.
(I find it quite funny that, when you’re treble-sensitive, these headphones obviously made to listen to music are just excellent for everything that is NOT music.)
Part 2: Changing the pads. AKA “I don’t get it. Sundaras aren’t 1 pair of headphones. They’re 1000 pairs of headphones.”
So, I destroyed the already-used-and-destroyed pads on my used Sundaras, only kept the round plastic “puck” – their non-standard way to “clip” earpads to Sundaras – and I’m now able to stick that “puck” inside any pads, and clip any pads to Sundaras. And if you started pad swapping with Sundaras
 I sympathize. I already said changing the placement on your ears 1mm left-right-up or down changes the sound 1db, so just imagine what pad swapping does. The amount of times you can change the sound and even technicalities of em by just swapping pads is just madness.
  • Get the standard pads for the obvious crisp, clear Sundara experience.
  • Get 30mm depth, “Sundara pads but leather-like”, and instead everything will be mid-oriented. More detail, but less dynamics, less soundstage, less treble and less bass. Makes for an excellent “studio neutral” sound (i.e.: They’ll just be boring).
  • Get huge-ass, leather-like angled pads, and you’ll get a V-shaped, very dynamic and punchy, mind-blowing big soundstage depth, more-than-speaker-like 3D-holographic experience in which everything “jumps at you”, all around you.
I swear, Hifiman are shooting themselves in the foot by not going “the IEM route” (like some IEMs now shipped with multiple filters). I’d ship em with the “vanilla” pads by default, but I’d add 10 curated pads to their website with a “choose your additional Sundara flavors”. If you don’t like the Sundaras sound
 try different pads.
P.S.: Yes, I know, I don’t have the official “pali pads”. They’re 50$ + 25$ shipping here. USD. I don’t even know if I paid 25$ shipped for the no-name Amazon pads I have, and I don’t think the official ones will tame the highs. Sundaras will still be Sundaras anyway.
got late to the train with these, in 2022-2023 something, and i almost wanted to sell them away, until i got Fiio K13 r2r dac, it’s the best combo i ever had with the Sundaras, no headphone are close to them in my list, r50x is not, hd560s is not, k712 pro - not, sony ma900 - nope, x2hr - no, Sundaras undisputed kings for me
 No way there is a better sounding headphone than that
I wouldnt say that, but in general most Hifiman headphones tend to work great with powerful, clean and linear amps.
Yes, I believe that to be true as well. For what it’s worth, I still use my Sundara on a regular basis and still enjoy it.
:backhand_index_pointing_up:
Me too!!!
Trying to compare to ad2000x by ATH, soundstage maybe bigger than sundara, but not lower than r50x, and Sundara still somewhat richer,knowing ad2000x used to cost 849£ at start?? For 2012 headphone Ad2000x still sounds magnificent, not gonna lie, after listening ad2kx i don’t like k702 and k712 anymore
 wish i never listened to praises of them and never tried them lol. Ad2kx with sundara (add r50x and/or hd560s to this list too) are headphones complimentary to each other
I have the revision of the sundaras with big leather type pads on them. Baught them second hand. I power them with an asgard 3. Is that a good pairing?
In a word
 Yes!
I concur. :backhand_index_pointing_up:
All this talk of the Sundara made me want to grab my pair and have a session with them, as it has been quite a while. This is still such a solid headphone. And super comfortable to wear. First word that came into my mind was - smoooooth. :ok_hand:
AMHD > Bifrost 2 > Liquid Platinum > Sundara :headphone:
