I’m looking for a device that will take 1 optical in and have 2 optical out.
This is so I can send my audio to my DAC for my headphones and also to my speakers which have a built-in DAC.
Only issue is that I’d rather not have the audio playing simultaneously, to be able to switch which output source would be ideal.
I’ve seen some that could probably get the job done on Amazon but they don’t look very high quality.
All I could find were the typical ones on Amazon and AliExpress. I would imagine they would be fine since they are splitting light and not an electrical signal.
Yea, I figured that’d be the case.
I’m not actually worried too much about the audio quality itself, just the build quality and usability of it.
I’m going to switching sources multiple times a day, some of these device don’t make it that easy to switch, some of the only let you switch via remote. It’s weird.
Thought there might be some super high quality version of these cheap ones.
