So my parents picked up a LG OLED 65in TV and they are using the built in audio which hurts my soul. I was able to convince them that they need a basic home theater style setup to complete their experience with that TV. They want to be able to use their xfinity remote to control everything so I am guessing ARC will be the best way to do this. I was thinking a 3.1 setup since they do want a clear voice track that is easy for them to hear. They want something that will “look good” so I’m thinking just a plain black wood vinyl/veneer. They want to spend under $1200 on the whole setup not counting cables and whatnot. I personally have the Klipsch reference line in a 2.1 setup for my home theater but I’m open to any brands.
The big issue with HT systems and acceptance for most people is the Wiring.
I have 5.1 in my living room for years, but my wife hated the cables, so I’m back to a soundbar and wireless sub.
You can certainly do a decent 3.1 at that price point.
But you should figure out what your parents are willing to put up with, Surround Receivers usually aren’t particularly small and easy to hide.
I would be able to hide the sub cable around the edge of the room so I don’t thing we will have an issue with that and if they can control the receiver with ARC I would be able to hide it in their TV stand. And for the right left and center channels I’m not to worried about those cables.
Then at that budget I’d start with a used 5.1 Receiver, they don’t hold their value at all.
That will let you maximize the money for speakers.
I’d look into that Xfinity remote. Sometimes they have some level of learning capability to serve as a universal remote. If it does, then you don’t need to go with ARC. That also opens more doors for used receivers as @Polygonhell suggests.
Oh good idea I didn’t even think of that! With those 2 options I’m sure I’ll be able to make it so only one remote handles everything
What about starting with something like this? Then you can build out and get 2 connected speakers front + 1 center and use these two as wireless rear channels for a 5.1?
