How ist the Noise isolation on the Fiio JD7?
Do the Fiio JD7 have good noise isolation or will I hear everything around ne?
I think it’ll be…average. Isolation did not stand out as a top positive, but I never thought about it as a negative either
Thank you :slight_smile:
I had the moondrop Aria iems. Do you think the JD7 will have similar isolation? :thinking:
Can’t answer that one
Alright. Thanks for all the help :grin: :pray:
