How much stuff can you blow up before 10am?
I want to cry, it’s not even yet 10am on 3/25/20 and i somehow managed to blow, 1 headphone tube amplifier and 1 set of planars both under 2 completely unrelated circumstances :sob:. Then to add insult to injury after walking away to compose myself and keep this curse which has hit me today from doing further damage, as I’m making myself a cup of coffee, the machine decides it’s not going to stop at 12 oz and now ther’es hot coffee everywhere too :face_with_symbols_over_mouth:
A pox has befallen me, please pray for my safety and survival. Total MSRP damages at this point, $2.5k…:sob:
I wouldn’t recommend you buying lottery. Not your day. :roll_eyes:
Tough day! :astonished:
Well depends how lonely I am that day… Oh you meant that “blow”? Awkward
Thank’s, I needed the laugh :joy:
It may just be me, but that loss of coffee would be just as upsetting to me. Lol
at least you have a couple earpads available if you run out of tp…
Which planar, RIP
Well look at the bright side. Now you can find something new and better.
im sorry for your losses =/
When you’re ready to explain (take your time), can you explain HOW this happened?
A broken tube amp? Now thats what I call a loss for the humanity. And i am not joking.
I once got pair of used, big B&W speakers delivered. dont remember the exact model, something with “5”. They were not that expensive, about 250ish about 5 years ago. While trying to get the big boxes up the stairs one fell down. When I hooked them up I saw that one of the drivers had gotten damaged and was crackling, buzzing. Replacing it would have cost another 200 so I let it go :stuck_out_tongue:
Might be stating the obvious here, but have you checked the fuse in the amp?
I have been confined to the house as many others and have limited ability to Telework so I decided to be pro-active and productive. I took apart my entire office system, diagrammed it and re-wired everything with care taken to wire management. I got done late last night and decided to fire it up for a test run first thing this AM.
I tested the 2.1 set up first: Innuos server -> Exogal DAC-> Decware CPS2/Pre-amp-> Sugden FP-4 Amp-> speakers.
After an hour of trouble shooting I realized the Decware was the issue. No output at any gain level other than maximum and no control via the volume knob. My heart sank, I really LOVE that Amp, oh well I’m sure it can be fixed.
Now that I knew I had a pre-amp issue, I wanted to make sure I could still use my Adcom amp to power my HiFiman HE6se’s somehow, so I re-wired around the Decware and just to test it used a small RCA to RCA adaptor to bring the ADCOM in line with another pre-amp to test.
Well, FML, i turn it on and get a dead channel on the right side, wtf, as I am reaching over to power down the amp I get a terrible buzz through both earpieces which almost blew out my eardrums. Fuck, fuck, fuck. I tested the headphones on a different amp, tested the wires. Dead headphones, both sides.
I’ve been so sick to my stomach over both incidents I refuse to power anything up today, there’s some kind of curse over me, i’m worried I’ll blow something else up too.
That’s as condensed and short as i can make it. Thank’s for letting me vent guys.
Yes, it’s not a fuse, it’s something weird. I also replaced all the tubes. It only works on max gain and then there is no volume control. I only tested this theory on headphone out, not in pre-amp mode. in that mode there is minimum output, you can hear something with gain at maximum thru the speakers, i almost believe is cross feed coming thru the DAC
Had you not been using the Decware for awhile? Could this have been a bad chain-reaction from an old and failing unit?
I wish that were the case. I just recently got the server, and spent last week figuring it out. I ran it through the decware and exogal and Sugden and the 3 pieces had beautiful synergy. So much so that i decided this was endgame quality which led me to re-wiring everything this week. I finally found my Nirvana and then promptly blew it all up :rage:
I can’t believe my luck…waiting on a call back from Decware, I’m sure we can figure out what happened. Literally all i did was unplug the unit and simply re-run the wires in a cleaner more organized configuration. It is an old amp though, circa 2006, things were bound to foul up and go bad…
I know from experience the driver wires probably burnt up, so if you fancy a quarantine DIY project you should be able to revive them with some soldering.
This is just sad man. Sorry that this happened. Sounds like my luck with Schiit a few years ago, lol.
