yes…2000 Ω headphones; the Senn HD424 to be exact. my FiL brought these over from Norway when he and the family came over in the mid-70’s. he says he replaced a driver in one earcup after one of his boys blew it out.
anyhow, they’ve been sitting for who knows how long and when I took them out of the original box (yes, he has the og box too!) I found the earpads to be so old they’ve oxidized and rotted. they’re like memory foam that doesn’t relax / reset. wearing them isn’t super comfortable but what remains takes the edge off the plastic edges, etc. I just finished ordering two pairs of replacement pads from Senn for $22 CAD shipped.
anyhow, my iFi ZEN CAN seems to be driving them just fine with the gain set to the third or fourth (and last) selected…but I want to make sure I’m not damaging it by running such high impedance cans through it.
I’ve played my number one bass test track, Decaf - White Clouds and I’m impressed. currently listening to the Westworld TV show OST by Ramin Djawadi. yup…am impressed!
I need to find some replacement cables for them though. the og cables are quite stiff and have bad harmonics when touched / bumped / rubbed. I found the Senn p/n 137974, which appears to be discontinued. being honest, the stock cable is so bloody long it’s ridiculous…but right now, if anyone knows where I can find a new cable, I will be indebted.
edit - I just found og replacement cables in stock at Economik for $32…so probably grab them, unless someone finds a much shorter and usable cable. ![]()
