I recently decided to splurge a little (in my case) on a set of speakers, so I bought the Edifier S350DB. I listened to it the first time and really liked it. Then comes the problem. I’ve noticed that when I have the speakers on there is a constant high pitched noise coming from the speakers. It doesn’t happen all the time but so far I would say 80% of time when I turn it on it’s there. I was wondering what could cause it and how can I fix it? Also since it’s my first time ever setting up something like this, I’m still a lost soul. From what I know of so far is that I don’t need an AMP, but did I need to get a DAC?
It’s a defect. I bought a second pair since I loved the first ones I got and it had this problem. I contacted Edifier support and they swapped my set.
EDIT: You don’t need a DAC either. If you use the Optical, Coaxial or Bluetooth inputs, you’ll use the DAC the speakers come with.
Okay! Thank you for the response! Gonna contact them right away now
